Bases with rounded corners??
Started by fulcrum, 10 December 2012, 06:25:47 PM
fulcrum
Leon,
Are you able to supply MDF bases with the corners rounded off (say a 1.5mm radius circle).
Regards
Lee
We've been meaning to get some of those sorted actually, to match in with a 'popular WWII 15mm' game...  :D
If you pop me the dimensions you'd like the bases to be, and we'll see what we can get sorted.
fulcrum
Leon,
I don't want them for THE "popular WWII 15mm game", but I'd be happy to go with whatever radius corners they use in order to make your life easier!!
I'll send you an email....
Regards
Lee
Quote from: fulcrum on 10 December 2012, 06:45:50 PM
Got it, I'll get back to you later on when I get in tonight.
You don't need bases with rounded corners to fight that particular popular 15mm game. In fact, gaming in 10mm, you can use whatever size, shape or colour bases you like!  :D
Quote from: Hertsblue on 11 December 2012, 09:29:46 AM
So what your actually saying is that you are not Basists, but quite possibly those rules who do specify a particular base style/ size or type are.  :)
To carry this thouht further does this mean those manufacturers who make figures for slotta bases are being segregationalist, as its a complete bugger trying to base thse figures in any other way, say on washers or coins.
Perhaps we should start a non-political, multicultural movement against figures that cannot easily be based on any form of flat base or any ruleset that insists on a specific base size. Perhaps the "Flat base Society"?
[tongue in cheek mode]
I reject you multiculturalism.
I'm basist and proud!
1" squares for F&F
Four by twos for DBM
Rounds for skirmishing
Got to keep them separate or they'll start mixing and we'll end up with irregular star pattern.  Then where will we be eh?
Bad enough we let ground scales go.
'As I look ahead, I am filled with foreboding. Like the Roman, I seem to see "the River Tiber foaming with measurement by multiples of base widths".
[/tongue in cheek mode]
:D
fulcrum
...before anyone shouts "follow the gourd"....
I prefer my vehicles on rounded corner bases and all my 10mm WW2 infantry will be based in twos on 20mm [rounded corner] squares
My Colonial Sudan is on 20mm squares, my ACW will be on 25mm squares but strangely my 10mm SYW is on 25mm [rounded corner] squares
I am consistent in my inconsistency!
Question - Is there a proper name for a square/rectangle with rounded corners? - and it isn't squircle, that doesn't have any straight sides.
Apparently the Bermuda Triangle used to be called The Bermuda Rectangle...
Until one of the sides mysteriously disappeared.
Lee
Albie Bach
Quote from: fulcrum on 11 December 2012, 05:09:57 PM
Rounded square / Rounded rectangle
Quote from: Luddite on 11 December 2012, 04:17:23 PM
:D
I thought a "basist" was someone with a large fiddle. Mind you, that sums up your average wargamer anyway.  ;)
Quote from: Albie Bach on 11 December 2012, 06:19:16 PM
You're not going to believe this, they are called 'Squircles'!
http://en.wikipedia.org/wiki/Squircle
Malbork
Interesting link there lemmy but am I the only person who can't see the difference between the blue squircle and the red rounded square? Or have I got my colours mixed? :-\
That's interesting....And I'm not sure if my eyes are playing tricks on me, 'optical illusion' wise.
To me....and I admit I may be imagining it....the 'blue' one at the top has sides that have a tiny curve in them.
The red one at the bottom....to me...the sides are straight... with the corners rounded off.
My imagination ?.....Or just my usual rubbish perception of (in this case) a couple of two dimensional pictures @-) @-)
12 December 2012, 03:57:35 PM #13 Last Edit: 12 December 2012, 09:46:17 PM by Leon
I am not multi-cultural. When in Rome etc. and obviously not PC ( see my jokes). :d  I also dislike the measurement with base widths. Unless they are 1 inch or 1cm as it means you have to constantly make calculations like
Infantry move 3 base widths and each base is 23.752mm wide so thats ???????? and My cannot fires 22.5 base withs etc etc.    :-\ :-\
EDIT: Quote fixed.
That wikipedia article is the type of article in which it is hard to know if it is true, or just an elaborate hoax.
