Spanish Civil War
Started by Nosher, 11 March 2010, 09:34:50 AM
OldenBUA
Quote from: DaveH on 28 November 2010, 01:15:56 PM
Actually looking at pictures if we could get the German Pak36 37mm as a separate gun then that'd work too.
Yeah, the 37mm PaK 36/36 was widely used. Sold to Russia, then licence built as the M30 (with spoked wheels, but I don't know if you'd see the difference in 10mm scale). License built in Italy (Cannone contacarro da 37/45), too. And by the Japanese as the 37mm Anti-tank gun Type 97.
The same type of thing happened with many other guns. The 40mm Bofors is the most famous, because it served with nearly all combatants (major and minor), with only small variations. Right now it's only listed with the British, but you can use it with every WW2 army that Pendraken currently have a range for, and then some!
Maybe it's a good idea to do seperate artillery crew and guns in the WW2 lists for this reason?
Aander lu bin óók lu.
It'd be a bit of hassle to split the guns and crews now, but we can always supply them separately if people need them.  Just get in touch with what you want and we'll sort it out for you.
OldenBUA
Quote from: Leon on 11 December 2010, 05:05:01 AM
Yeah, it figures that splitting the guns and crew would be a hassle. But it's good to know that you can do that, if the need arises.
Note to self: Must have a good look at the WW2 British list again...
