worst task in wargaming
Started by Sunray, 23 June 2012, 04:44:52 PM
Aart Brouwer
Quote from: Maenoferren on 23 June 2012, 11:29:29 PM
trimming the flash off the bases when you have lost your snippers so it has to be done with a sharp blade, always best to count your fingers before and after to ensure the tally at both counts is the same, or if you cut it off on a board ....apologising to wife, children or pets as you embed subsonic pieces of pewter in them at 40 paces.
I use a polishing pad on my drill for this. Mount drill in bench vice, switch on drill, lightly touch bottom of model to rotating pad, and you have a perfectly flat base underside in 1 second.
Aart
Quote from: Aart Brouwer on 24 June 2012, 08:50:48 AM
Aart
Dear god!
Clearly you have never seen me near power tools :o I'd be in A&E within minutes of turning the drill on ;D
robert
The worst task in wargaming imho is deciding which rules to use for a period...............then resisting looking at a new set..........but finally giving up and deciding to use the new set ........
and then getting to the worst task which is of course  :(
That is the sort of bloody nonsense up with which I will not put - Winston Churchill
robert
and for some reason my last post missed the last word :-\
REBASING
Have to agree, it's rebasing, eg. Maurice - all figures on same size frontage; damn, my cavalry and artillery were on wider frontages - and yes, it does make a difference.
Shecky
I think rebasing is admitting a past project is a failure. Perhaps that is why a lot of people don't like to rebase - it means we have failed at something.
robert
I rebased my 28mm for Maurice but I really cannot see me ever doing that again with these figures - they were based for Piquet Cartouche and Grognards which comprehensively failed for me - agreed.
All my 10 mm will be based to Warmaster/Commander series and this time I have stopped at looking at other 'new' rule sets and will concentrate on what I now have - so yes - if I was to ever rebase
that would be a failure - so it is not going to happen :-\
basing to a set tht DOSN@RT USE A BASE SIZE !
Good un.
Yep, it's got to be rebasing - each time I do it I swear I'll never do it again. However, it's a lot easier now I've finally cured myself of setting the little so-and-sos in Tetrion.  #:-S
robert
@ Ian S - were you replying to me?
If so I have completely missed your point - sorry.
The little blighters have to be stuck on something (which I call bases) and then you come unstuck when the new rules insist on a different size or grouping and re-basing is only option if new rules are to be used.
Maenoferren
Aart
hmmmm worth a try  :D
Quote from: Shecky on 24 June 2012, 03:43:24 PM
Not at all.
For me it usually means that i've taken up a new ruleset and because no rules use the same basing conventions...   >:( :'( >:( :-w #-o   ...it means i have to rebase the damned things.
Often you can get away with it since modern rulesets have largely abandoned any pretence to simulation and are mostly gamist in nature, but for some the base size is vital.
TinyTerrain
Its funny because I quite like basing. I always think of putting a good scenic base on a figure is a bit like putting a frame around a picture. Get it right and it makes a good picture look great, and a great picture look fantastic. Well worth taking your time over, IMHO (especially with 10mm as the base is so much bigger than the individual figures).
My most hated job is cleaning off flash, and glueing together multi part white metal kits, the cutting I loose fingers and the gluing I stick what few fingers I have left together again  ;)
Cheers,Craig
Tiny Terrain Models
http://www.wargames.blog.co.uk
All Periods, All scales
J.S.
I hate basing...got several armies which wandered into a shoebox after completing the painting. Latest 10mm example: Sassanid Persians
2013 Painting Competition - Runner-Up!
Quote from: TinyTerrain on 24 June 2012, 11:07:25 PM
Ooooh good one.
Yeah, i hate this too.
Lots of flash = poor customer service*.
But multipart figures really annoy me.  I still have 4 boxes of unopened Perry 28mm Wars of the Roses models.  Got part way through the first box and just could not be bothered to finish gluing all the uneccessary fiddly bits together.   >:(
Don't get me wrong, multi-part where it allows you to vary poses, isn't too bad (i still hate it though), but most of Perry's stuff has ONE POSE.   >:( >:( >:(
* The best company i've found on the flash score is Dark Realm Miniatures.  Not only are their 6mm castings clean, they've evidendly been cleaned of flash before shipping.  They're pricey but i'm willing to pay that little extra to get clean models.
Of course Pendraken's castings are usually pretty good too.   ;)
