Michaels 10mm 1809 BLOG
Started by WeeWars, 01 May 2012, 11:55:13 PM
That granary is a lovely piece of work.
WeeWars
Thanks!
The Essling base board is progressing:
POST 216
www.michaelscott.name/1809/blog2015/1809blogpost216.htm
Cheers, Michael
www.supremelittleness.co.uk
Let that cure for a week or so sir, then add another thin layer, it should help level it.
That pond looks great to me 8).
The photographs look good. Very effective. I know you said green/brown but what colour of paint did you actually add? Would also be interesting to hear if Lemmey's experience of letting it cure for a week will work in your example.
WeeWars
I first experimented with brown ink but it didn't appear to make much difference and left the pond too crystal clear for my liking. I then used Coat d'arms Dark Earth. It was very green, which looked good but the tiny amount I used hid the depth of the pond. Next attempt, I used Raw Umber which is a more transparent pigment. One problem is that the pond is very small so there's little opportunity to dilute a mix and difficult to forecast how it will turn out. I'll give Will's excellent idea a try but I may have scuppered my chances as now there's even more overhanging vegetation for the expanding polyurethane to seep up.
My experience with it is that any flock or scatter will wick like crazy, but I guess you've figured that out!!
Maybe make a thin former or coat the area in cling film before applying, let it dry, then peal off the cling film and apply as a separate slab with pva (which dries clear and mat) around the edges?
Or leave it, as it looks cool... ;)
WeeWars
Wick, yes. It literally defies gravity! I thought placing a tuft in the water would be a nice idea until I saw the polyurethane rise up the grass above the level of the pond!
It's a very small water feature so I may leave it as it is. I prefer a certain amount of ripple on the water's surface, anyway. And the human eye sees it less clinically than the camera!
Or just have some cavalry drinking from the pond?
WeeWars
And some Old Guard having a swim  :)
WeeWars
