19 May 2013, 04:03:28 PM
The May Releases are now available!
75801 Posts in 6090 Topics by 1172 Members
Latest Member: AlberthaS
|-+  Archive
| |-+  Competitions
| | |-+  Pendraken Painting Competition 2012!
| | | |-+  Armour Decals
Pages: [1] 2 Go Down Print
Author Topic: Armour Decals  (Read 1417 times)
« on: 21 February 2012, 09:49:42 AM »
Need the correct (well, as correct as possible) decals for my 14th Army Lee tanks. I assumed that Pendraken would stock something suitable, but I've scoured the site and the Minibits site and come up empty . So, where do I go?
When the going gets tough, the tough go to lunch....
ianrs54
« Reply #1 on: 21 February 2012, 09:54:23 AM »
Sorry to be negative - but as far as brigade markings I think you are going to be a bit stuck. The red tac flash should be fndable, since the British forces regularly changed these. Squadron tac markings (carried less often than people think) will be standard.
Try Doms Decals as a starter
Luck
More Modern Stuff
« Reply #2 on: 21 February 2012, 10:50:58 AM »
Cheers, Ian. Much obliged.
Gandalf
« Reply #3 on: 21 February 2012, 11:43:00 AM »
Minifigs supply a range of decals that will cover what you want
http://www.miniaturefigurines.co.uk/Catalogue.aspx?ScaleID=1&CategoryID=1&SubCategoryID=12
Have you seen the rivets on that?
fred 12df
« Reply #4 on: 21 February 2012, 07:27:28 PM »
The  British Armoured Divison sheet from Minifigs is very good.  It has Arm of Service markings, squadron symbols, white stars, bridge markings. The only thing that is a bit weak is divisional markings, as there are no were near enough to go with all the other markings.
Doms Decals are good but are mainly 15mm and Division and Arm of Service are too big for 10mm vehicles.
I'm not sure what markings 14th army used, but by 1944 markings in NW Europe had been standardised. See my web page here for 7th Armoured Div http://www.kerynne.com/games/British7thArmouredDivision.html
« Reply #5 on: 22 February 2012, 09:22:16 AM »
Can't seem to get that one to come up, Gandalf
ianrs54
« Reply #6 on: 22 February 2012, 10:39:35 AM »
Muist admit didnt work for me either.....
Ian S
More Modern Stuff
« Reply #7 on: 22 February 2012, 12:11:17 PM »
Found some useful info at www.fireandfury.com/painting/burmaarmypaintingguide.pdf.
I'm aiming to do 149th RAC (or part of it at any rate) as they actually relieved Kohima.
fred 12df
« Reply #8 on: 22 February 2012, 05:21:01 PM »
I've not seen the red over yellow Arm of Service markings before. I don't think they are available on a commercially produced 10mm decal sheet.
It's not too hard to produce your own, blank decal paper is available from eBay either clear or white. White produces brighter colours, but needs cutting out very neatly. In the past I have used a colour laser printer as then the printing is water proof which isn't always the case with ink jet printers.
Gandalf
« Reply #9 on: 22 February 2012, 07:27:03 PM »
Odd but it work's fine on my computer.  Try going to the Minifigs site and look in 12mm World War II on the "transfers" tab
fred 12df
« Reply #10 on: 22 February 2012, 08:16:45 PM »
Strange, worked for me last night, but not now. Navigating in from the home page works though.
« Reply #11 on: 23 February 2012, 08:48:18 AM »
I might just crank up the old Samsung and try that, Fred. I'm always preaching self-sufficiency, after all.
Yeah, that's what I did eventually. They seem very expensive for what they are.  Sad
Ray
fred 12df
« Reply #12 on: 23 February 2012, 05:10:25 PM »
The scale specialties sheets aren't cheap. The British NWE one is good as it has loads on it, but the British western desert one is quite sparse.
If you are going to have a go at making your own,be sure to do some test prints on plain paper to check you have the sizing right.
« Reply #13 on: 23 February 2012, 07:37:04 PM »
Thanks for the Fire and Fury link Hertsblue, very useful Smiley.
« Reply #14 on: 24 February 2012, 09:08:57 AM »
Yes, I've tried that already. The little devils are surprisingly tiny!
Incidentally, the 254th Armoured Brigade, to which these units belonged, was an Indian Army formation. This may explain why the tac-signs seem unfamiliar.  Undecided
Pages: [1] 2 Go Up Print
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
