19 May 2013, 02:02:08 AM
Too late for Triples pre-orders now, we hope to see you there!
75781 Posts in 6090 Topics by 1172 Members
Latest Member: AlberthaS
|-+  Pendraken Topics
| |-+  New Releases
| | |-+  2012 Releases!
| | | |-+  Falklands War - Early Wip pics.
Pages: 1 2 [3] 4 5 ... 15 Go Down Print
Author Topic: Falklands War - Early Wip pics.  (Read 14428 times)
Major General
« Reply #30 on: 06 January 2012, 10:34:19 AM »
Cheers Nosher.
That certainly IS a big piece of kit....My pretty (flat art..not photos) piccys must incorrectly show the newer model.
I'll just leave one of those and pick the others off.....Might even save that just for a prone sniper if one's required ?
Question you might be able to answer for me ?.....Again looking at pretty flat art, they seem to portray 'something' tacked on to the end of some of the SLRs....A flash eliminator ?
If I can do a not too chunky version of whatever it is, I can elongate the barrels by adding that....Otherwise I might try a 'dodge' I picked up from the Perrys, but have never tried myself..... rather than messing too severely with the models. Undecided
Thanks - Phil.
I'm glad I don't have to pick out all the bits of putty from the mould after this is pressed.
« Reply #31 on: 06 January 2012, 10:42:16 AM »
Phil do you have a photo/pic of the 'something' tacked onto the end of some of the SLR's? Yes there is a flash eliminator at the end of an SLR barrel but in 10mm it would be negligible?
The only thing that springs to mind we ever 'tacked' onto the end of an SLR barrel (other than a bayonet!) is a blank firing attachment
Might be able to help if you have a pic thats postable or a webpicture?
See all, hear all, say nowt;
eat all, sup all, pay nowt;
and if thee ever does owt for nowt,
allus do it for thisen.
Yorkshire born and Yorkshire bred. Strong in't arm and thick in't ead!
Major General
« Reply #32 on: 06 January 2012, 10:52:43 AM »
Hi Nosher.
Even in the 'pretty pics' it's relatively tiny....I'm sure it must be a flash eliminator.....
I'll have a 'play' with just one of the SLRs to see what it comes out like....Think I can make it work, without it looking silly (fingers crossed)
Amazingly....Pretty sure I know what the blank firing attachment looks like....Good bit more noticeable.
Thanks - Phil.
Dazza
« Reply #33 on: 06 January 2012, 06:00:39 PM »
not something like this then ?
L1A1 - Muzzle cover (It is of a rubberised foam construction, 15cm overall length, and attatches to the rifle with a hole in the tail, which you pull over the bayonet lug.)
or could it be one of these :
the L6A1 BFA, its a massive, solid BFA capable of trapping a bullet if needed.
Left to Right
 Canadian C1 BFA
 Canadian C1A1 BFA (also British L1A1 BFA)
 British L1A2 BFA
 British L1A2 (modified) BFA
 British L6A1 BFA
 Australian BFA
« Last Edit: 06 January 2012, 06:10:58 PM by Dazza » Logged
Dazza
Dazza's 10mm Miniature Armies
http://www.ukstrike.co.uk
" Member of the Tarleton Brigade"
Never argue with an idiot;
He'll drag you down to his level and beat you by experience.
Rob
« Reply #34 on: 06 January 2012, 06:39:05 PM »
Miles laser?
http://en.wikipedia.org/wiki/Multiple_Integrated_Laser_Engagement_System
mad lemmey
Major General
« Reply #35 on: 06 January 2012, 06:42:54 PM »
In 1982?  Shocked
ianrs54
« Reply #36 on: 07 January 2012, 09:17:22 AM »
In 1982?  Shocked
Yep -  but not I think on rifles.
BFA's were normally the smaller types.
The II sight is a Starlight Scope - large and heavy.
More Modern Stuff
Major General
« Reply #37 on: 07 January 2012, 09:39:33 AM »
Shoot me down in flames Guys...
But....As far as the sights are concerned....Could it be that the artist has taken his reference from the sights that the Argentine army used on their SLRs ?
From the limited research I've been able to do, it appears that the 'bad guys' had more up to date resources than our chaps....(Though they blamed their defeat on THEM having inferior equipment.)?
The 'flash eliminator'......It's been portrayed as something much 'cleaner and neater' than Dazza's rubber thingy pic.....Can't believe it's supposed to represent any of the yellow 'wossnames'.
But the help is VERY much appreciated.....
Thanks All - Cheers - Phil. (who's very dazed and confused this morning.....Bought myself a spiffy new soldering iron which arrived yesterday.....I reckon I've given myself an overdose of Butane.....Couldn't get the damn iron to fire up.....Over and over and over again.... But would I go outside in the fresh air.....No "It'll go next time " !
Boy did I feel horrid last night.
« Reply #38 on: 08 January 2012, 10:40:48 PM »
Might be worth having a look at the Vietnam Aussies Phil - their SLRs look great...
Loads more pics here: http://nikharwood.pbworks.com/w/page/7825429/CWC%20Australian%20battlegroup
Major General
« Reply #39 on: 08 January 2012, 10:51:54 PM »
Ta Nik.
I'm going to have a go at lengthening the SLRs I've done on the models already, using a tiny speck of solder on the very tip of the barrels (and then neatening them up with my custom made 'emery boards' and a miniscule smidgeon of putty.)
If that doesn't work I'll redo them....Though I'll probably have to have a hissy fit first. Grin Grin
Cheers - Phil. (Good paint job on the sci-fi marines Matey...Spot on !)
Smee
« Reply #40 on: 10 January 2012, 02:03:37 PM »
During the conflict Brits didn't have many sights as standard (relied mainly on the iron ones) so could be a waste modeling them with, a more common sight than the night sight was the early version of a SUSAT which was detachable. The 1980's SLR was exactly the same as the ANZAC SLR for sizes and visual aspects. It was also fairly rare to use the carrying handle as the sling was a lot more comfortable and left your hands free.
The LMG (converted Bren gun) was also used by the engineers as the standard section LMG, and dont forget the SMG issued to rad ops and officers, amongst others Wink also  a M2 .50 cal was used for air defence.
Just a thought but if you model the para's they had para helmets instead of the old metal basin everyone else had. A lot of troops (especially the marines) had civie items like gaters and bergans.
A BFA would not of been found anywhere near troops in combat btw Wink
TimeCast
« Reply #41 on: 12 January 2012, 12:51:26 PM »
C'mon Fred
It's Swiss roll for goodness sake.....Isn't it obvious ? Wink
Oh ....all right then..It's his sleeping mat rolled up.
You can't see it from the front, but the chap on the right of the British forces is loaded up to the nines with kit.....So I thought I'd do one of the Argentinians in a similar fashion.
How those guys carried all that stuff is totally beyond me....I don't think I could even lift the British kit onto my back.....Let alone march mile after mile with it....Stroll on !...Full of admiration for them.
Most of the guys only carried fighting order rather than lugging the bergans around as well, particularly on the march across the island. However, fighting order usually came to well in excess of 50lbs even without all the extra ammunition, heavy weapons etc. A Milan operator's fighting load came to well over 120lbs IIRC. My kit (including rucksack) weighed in at about 104lbs and I only carried an SMG. A lot of the weight came from the extra arctic clothing (oversmock, waterproofs, quilted under suit, underwear etc) and rations which filled the rucksack. Fortunately I only had to walk about a mile carrying that lot, the rest of the time I moved by helicopter.
Anyway I digress. Here at TimeCast we have been liaising with Leon regarding this range and we are planning on have a range of buildings and scenics for the Falklands war ready for April. The models will be based on photographs (as usual), including some from my own photo album. Keep any eye on the TimeCast website in the next couple of months.
Barrie
TimeCast
EDIT: Quote fixed.
« Last Edit: 12 January 2012, 02:55:00 PM by Leon » Logged
mad lemmey
Major General
« Reply #42 on: 12 January 2012, 01:02:07 PM »
Hello Barrie!
 Nice to see you here!  Cheesy
Will
« Reply #43 on: 12 January 2012, 02:02:52 PM »
REALLY GOOD to note that Timecast will be backing this venture too Wink
Already putting pennies away for this one!
OldenBUA
Captain
« Reply #44 on: 12 January 2012, 02:08:21 PM »
Or as some would say "Top-notch".  Cool
In countries with low English skills, just shout LOUDER.
Pages: 1 2 [3] 4 5 ... 15 Go Up Print
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
