Marlburian range
Started by Lovstrom, 30 August 2011, 10:03:32 PM
Lovstrom
Hello
Is there a french dragoon in the Marlburian range?
Both as mounted and infantry.
Sven
I presume you mean in the soft(stocking?) cap as opposed to the tricorn. There isn't at the moment so I would add this to my request list:
WSS - French dragoons in stocking caps mounted and dismounted.
WSS - French hussars
Lovstrom
Yes
You just had the names for it.
To be honest I didnt think about the hussars but of cause they are needed too.
I am thinking of a French army in 10mm sp can we have them please?
Sven
Here's another thought - where are the personalities: John Churchill, Prince Eugene, Neufville, Chastenet etc.
DP
Chad
We have used the SYW mounted dragoons, but a dismounted Dragoon in stocking cap would be useful.
Still do not understand the fascination with the Hussars of the period.  :-\
Chad
Quote from: Dour Puritan on 03 September 2011, 08:57:39 PM
DP
Yes, indeed. I asked the same question ten years ago. At that time there wasn't even a generic general in the range.
I ended up using the Russian dragoons (mounted and dismounted) from the GNW range. Not perfect but in 10mm better than tricorns!
Graham
The WSS French do not need any more troops.  If you bring them out Sunjester will buy them and use them against my Imperial army.
Nirnman
might I second or even third the call for WSS personalities.
holdfast
Doesn't Clib's new LOA range include dismounted dragoons in stocking caps?  Perhaps they might be compatible.
Damn.  I don't know what to object to. French WSS or Centurion Tanks.
You're not likely to meet Centurions in eighteenth century Brabant.
But its the principle of the thing.
Quote from: Last Hussar on 10 August 2013, 12:35:43 AM
Even better, French WSS with Centurion tanks!  :d :d
