Advice, please; crumbly plaster model
Started by FierceKitty, 19 July 2011, 02:33:15 PM
I've just bought a very pretty but very fragile model Hindu temple, just about the right scale, The thing appears to be made of a low-grade plaster. I'd love to use it for a BUA in Moghul games, but fear it wouldn't survive. What can I do to make it more durable? Fifty coats of varnish?
Dip on a mixture of 50% water 50% pva?
Squirrel
Spot on Lemmy, that will work perfectly. The same mix is used in the construction industry to stabilise crumbly brick or plaster wall surfaces too. Just coat with car primer spray afterwards as water based paints won't adhere properly to the pva.
Kev
Maenoferren
Yep - diluted PVA will do the trick; I'd be tempted to give a couple of thin coats rather than one thicker one. You could [potentially] add in some pre-mix plaster / spackle [eg Polyfilla in the UK] to the thinned mix - this'll strengthen too...and if you want some additional texture, bung some sand in too.
I've said it before & I'll say it again...mad feckin scientist, me  :d
GordonY
OR make a Latex mould and recast it in Heculite II, it'd survive being smacked with a 3lb hammer then.
Quote from: GordonY on 19 July 2011, 11:11:22 PM
True, true  ;D :-bd
Maenoferren
I use Kerramin for my plaster, solid stuff :D
