Army Painter System
Started by Hertsblue, 11 February 2011, 10:34:48 AM
Sean Clark
Those blaggards may indeed need flogging :), but I suspect you meant to say flocking =O
Sean
God's Own Scale podcast
Quote from: Dour Puritan on 14 April 2011, 07:06:56 AM
They look good but I think I'm still inclined to go for soft tone.
DP
I think we're now into the realms of personal preference :)
tjantzen
Quote from: salagam on 14 April 2011, 03:30:04 PM
Sean
I guess both would do them good  :D
Dansk Figurspilsforening - http://www.krigsspil.dk/
Quote from: GordonY on 13 February 2011, 10:01:56 AM
This
remember to thin it with some water, this Punic cavalry were done with this stuff.
Gordon
EDIT: Pic resized.
~Do you have any close up's of the figures you have used with this mix?, and have you used it on 28mm figures?
GordonY
Yes I've used it on 28mm figs, closeups just show up my horrid painting but I'll try to get some piccys done this week sometime.
Has anyone had any long-term problems with the B&Q type varnishes?  I was chatting to a guy a few shows back about alternatives to Army Painter, and he mentioned that his figures had become discoloured over a couple of years, turning white?
GordonY
I've been usint that tin of B&Q for 3 years and no problems so far.
GordonY
Ok for Fenton here is some 28mm Skaven
and a closer look at some AWI 10mm militia
That do mate?
Gordon
The photos make it look fairly glossy. I find the problem with commercial varnishes (i.e. the big-tin DIY stuff) is that you can never be certain what finish you will get. Even the nominally "satin" finishes come up fairly glossy.
Mind you, a lot of people like them like that - it's all a matter of taste I suppose.  :-bd
GordonY
Yeah it does come out glossy, but nothing that a splat with the Dullcote doesnt fix.
thanks mate for the photos...off to B&Q I go
Sorry to revisit this one...I went to B&Q yesterday to get some varnish. stain to give it a go...GordonY what product did you buy? as I think I got the wrong stuff, and your pics of the pin are no longer showing
GordonY
B&Q Quick Drying Floor Varnish, Rosewood shade, about £9 for a 750ml tin. Should be the clean brushes with water type, usual B&Q green own brand tin. Hope thats clear enough to get the right stuff.
Many Thanks Gordon...wonder if I can take the stuff I bought back
B&Q are normally very good about returns - usually 30 days if you have the receipt. If you are wanting to do a swap then it should be absolutely fine.
