Consistency - ever heard of it?
Started by Raider4, 09 March 2021, 08:46:59 PM
From a scenario I've just read:
"A river approximately 4" wide runs across the centre of the table from side to side. 12' from each side table edge is a ford 120mm wide."
That's quite normal in my wargaming. I'll mix imperial and metric all the time - tanks have speed in kmh, armour in cm, angles in degrees, guns in mm, penetration in cm, weight in tons, dimensions in feet, aircraft range in miles, firing range in metres.
Shock horror I even use dice with different numbers of sides together  :o
Inches are still good size though, metric missed out there when it didn't make an equivalent unit.
It probably helps I can convert both in my head, eg knowing 15" is 38cm or whatever, or know the conversion ratios off by heart, eg 1.61kmh to 1mph.
Quote from: Raider4 on 09 March 2021, 08:46:59 PM
Twelve feet from each side table edge!!!!! How big a table are we looking at? Answers in either metric or imperial are fine. Though preferably not in rods/ poles/ perches!!
flamingpig0
I was taught in metric but know imperial due to wargame rules- using both seems quite natural
 H.P. Lovecraft
Salah Askar,
I quite often fnd myself looking for a piece of weed in the garage for a job thats 38" X 20mm.  Its whatever is the nearest on the tape measure
At school I started in Imperial, then we had to transition to metric (I can still remember the wooden rules we were given with cm's on them to help learn). In my former work everything small was in millimetres (never cm's) yet making furniture or bigger 'things' I still use Imperial.
Quote from: Orcs on 10 March 2021, 01:33:55 AM
A piece of weed ?
That's one hella of a spliff! ;D
Quote from: Ithoriel on 09 March 2021, 10:55:48 PM
This was my thinking,I think the correct measurement for a table of those dimensions is "bloody massive".
I learned metric growing up, while Imperial was only used conversationally for human heights and weights and road distances.
For smaller measurements though it was always metric so wargaming has taught me some useful conversion skills with inches and cm. Though I do mostly use metric for measurements as often gaming in small spaces.
WEll I have plaed on tables over 30 ft long, since we had access to the upper floor of an aircraft factory.
Quote from: sultanbev on 10 March 2021, 08:36:58 AM
A piece of weed ?
Beat me to it, Sir!  ;D
Black Powder has base sizes in mm, and movement in inches. Had to do the maths when I converted them to cm movement.
Also, post lockdown party at the Orcs.
Quote from: Last Hussar on 11 March 2021, 07:27:08 PM
To be fair, an awful lot of games use that convention.
Honourable exceptions are Warmaster, Epic Armageddon and the Commander series, all firmly metric. I'm sure there are plenty of others.
Local DIY store to my mum used metric feet.
Heedless Horseman
12 March 2021, 04:03:32 AM #14 Last Edit: 12 March 2021, 04:06:01 AM by Heedless Horseman
Was taught 'Feet' and 'Inches' as a kid...BUT, THEN, 'they' went 'Metric', so never have been able to get my head around 'fractions'! :(
So: 'Big' is in 'Yards / Feet / inches', 'Small' in mm!  ;D
