Welcome,
Guest
. Please
login
or
register
23 January 2021, 01:17:25 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Our
Peninsular Napoleonic
project is complete, updates coming soon!
314793
Posts in
18224
Topics by
2282
Members
Latest Member:
josh_davidson
Wider Wargaming
Rules
10mm Regimental F&F Basing advice
« previous
next »
Pages:
1
2
Author
Topic: 10mm Regimental F&F Basing advice (Read 1055 times)
Battleback
on:
25 September 2020, 09:00:58 PM »
While I'm putting together my German order for my 1944 Ardennes Project, I would like to add a little "New Project" seed to my my box of goodies. I've been waffling back and forth on what my next project should be (AWI, Napoleonic's, ACW) and I've decided to go with the ACW.... At least for the moment
So, since I'm the type of person who can't stand to start a project without first laying out how I will do the project before hand, I've come to ask the good people on the forum for some basing advice.
I'll be using 10mm Pendraken Figures and right now I've thought about either basing the figures on the "15mm Scale" basing recommendations (25mm x 20mm) and just using more figures per base or using the same figure count as the "15mm Scale" recommendations on smaller bases (20mm x 15mm for example).
I thought if I use the 15mm Scale recommendations then I could probably do 2 ranks and count each base as two bases and just mark the base after hits, and spacing them out when in extended line formation. Going this route I would base them 4 figures per rank 2 ranks deep. This would result in a higher figure count but would cut in half the total amount of bases needed to play. Then use the 15mm rules for measure etc.
If I use the smaller bases, something similar to 20mm x 15mm I would base them 3 per base like you would with 15mm figures and probably use the recommended 6mm scale measurements when playing. This option would result in the same amount of basing and figure count, but I might need to use a movement try to speed up play?
I would be basing both sides and only playing with my son and friends so there's no worries about matching up with other players at a clubs etc. But I would also like the bases to be flexible enough to use on other rules systems.
So anyone have ideas which way I should go?
How have you based your 10mm ACW?
If you were to do it all over again would you base them the same way or would you do something different?
Thanks, any and all advice welcomed!
Rally Rule for Hits in BKC:
https://drive.google.com/file/d/1Zk5nWfvO3-BAyqysBoKHdPyfK3-LiLBG/view?usp=sharing
kipt
Re: 10mm Regimental F&F Basing advice
Reply #1 on:
25 September 2020, 09:08:50 PM »
I am using 4 figures in one rank (1" x 3/4" stand - I am in California) for infantry and 2 cavalry in one rank (same stand size) I put guns and limbers on the same size stand (1" x 1-1/2"), 1 gun and 4 crew for the gun stand and the limber with 2 horse on the limber stand.
Reply #2 on:
25 September 2020, 09:34:28 PM »
I don't play Regimental F&F
For other rule systems my approach is to use the 15mm basing and double the number of infantry figures, basing them in two ranks. Cavalry in a single rank with perhaps 1 or 2 more figures per base. I then treat them as a normal 15mm base.
Personally I would find 20x15 bases small and fiddly, they are also more likely to fall over on hills.
I suspect 4 figures per rank is going to be tight on a 25mm wide base, for my DBA armies I use 4 figures in two ranks on a 40x20 base
2018 Painting Competition
- Runner-Up!
Reply #3 on:
25 September 2020, 10:22:12 PM »
I also don't play F&F or yet own any ACW figures but I've found you generally need around 8mm ground space to fit a figure on in a tight formation. So if you went 25x20 you could probably fit 6 figures, 2 rows of 3. Which would look pretty good. 20x15 might be a bit of a squeeze to fit more than a couple of figures on. You might be able to do it with a bit of base filing but I'd probably go with the 25x20 (or even 25x25 to be a bit less tight fitting).
I often agonise over basing, I find the best thing to do is get some bases and figures and stick them on until I find what looks right. Then abandon that idea and try a few other variations. Then abandon them and eventually find the one you want to go for.
Then just stick with that or else you'll spend forever rethinking basing!
https://mmcvhistory.home.blog/
Battleback
Reply #4 on:
25 September 2020, 10:52:00 PM »
Thanks for the tips everyone! This is my first time basing for a game that uses formal ranks and really finding it hard to choose a basing scheme.
@paulr, those figures look amazing and I really like the spacing.
@mmcv, thanks for the 8mm tip, that gives me a good starting point on how I want to proceed.
I think I might go with 3 across and 2 ranks on the 25mm x 20mm. But I also might go with the same figure layout on 30mm x 20mm which mirrors paulr's spacing of 10mm between figures, giving them a little more elbow room.
Now the question is how would it work in RF&F to use the double rank bases and count each base as 2 stands? Has anyone played it that way? On the surface it sounds like a great short cut but maybe I'm too optimistic?
Sent from my SM-N960U using Tapatalk
Major General
Sir Oik of Westmarch
Reply #5 on:
25 September 2020, 11:15:21 PM »
Why complicate life by saying one stand equals two, etc.? I say just take the recommended base sizes and fit as many 10mm figures on this in such a manner that floats your boat.
Battleback
Re: Re: 10mm Regimental F&F Basing advice
Reply #6 on:
25 September 2020, 11:27:22 PM »
Quote from: Westmarcher on 25 September 2020, 11:15:21 PM
Because I can do a 200 stand battle with a 100 stands. The figure count would also remain the same as a standard game. Otherwise if I count 1 base as 1 base, I have to base 200 stands and paint 1,200 figures instead of 600 figures. I'm looking for a short cut.
Major General
Reply #7 on:
26 September 2020, 12:00:59 AM »
Another solution is to make your own measuring sticks. For example, I like the Field of Battle rules but these are written for 28mm figures and measurements in inches. The standard base size is 1.5 inches square (4 bases per unit). That's too large for my table space and 15mm and 10mm figures so I use 1 inch square bases instead (the width of which, coincidentally, was influenced by the brigade F&F rules). As mentioned, when I play FoB, the measurements are in inches, so what I've done is make my own measuring sticks so that an "inch" actually equals something less. Ideally, I should have a set of sticks where an inch is actually 2/3rds of an inch (1 inch being 2/3rds of 1.5 inches) - instead, I have 2 sets of sticks - one set where "1 inch" is actually 2cm and another set where each inch is actually 1.5 cm. Bottom line is you decide how long a game "inch" should be. This then allows you to reduce the base sizes to whatever you want to fit in with your own preferences regarding base size, figures per base and the table playing area available to you.
p.s. Btw, personally, if a set of rules requires me to paint a million figures to be based on a thousand stands, I would ditch them for something that I could cope with in this lifetime. At my age, life is getting too short. There's loads of good rules out there. Just a thought.
Last Edit: 26 September 2020, 12:08:37 AM by Westmarcher
kustenjaeger
Reply #8 on:
26 September 2020, 12:10:15 AM »
At present I am using 4 infantry figures in a single staggered line on a 25x15mm base. I am not sure this is the right answer but it looks OK. Obviously with two stands deep it still looks a bit deep unless you have a reasonably large number of stands in the unit.
Edward
kipt
Reply #9 on:
26 September 2020, 12:41:04 AM »
You could also look on the Regimental Fire and Fury forum at fireandfury.com. There has been discussion about 2 ranks on a stand.
Shedman
Reply #10 on:
26 September 2020, 07:45:33 AM »
I would go with 5 or 6 infantry figures on a 25x25mm square base
T13A
Captain
Reply #11 on:
26 September 2020, 08:53:28 AM »
You might want to look at this excellent blog, although it is aimed at Brigade F&F I'm pretty sure the basing is the same for the Regimental version:
http://www.jemimafawr.co.uk/2020/02/01/playing-brigade-fire-fury-2nd-edition-in-10mm-i-did-it-my-way/
Great period and rules and an AAR here:
http://www.jemimafawr.co.uk/2020/07/27/gettysburg-2nd-july-1863-sickles-salient-a-solo-refight-using-brigade-fire-fury-2nd-edition/
There are some others if you search around the blog.
Cheers Paul
Major General
Reply #12 on:
26 September 2020, 09:40:08 AM »
Quote from: T13A on 26 September 2020, 08:53:28 AM
What my whisky adled brain was trying to say last night (reduce base sizes and make own measurement sticks).
Well painted figs and nice looking layout. Once again leaving me wishing that Pendraken had brought out their ACW range sooner before starting my own 15mm ACW collection.
Major General
Thread Derailment Specialist
Reply #13 on:
26 September 2020, 04:00:13 PM »
I am basing mine on the 15mm recommendations for F &F
5 infantry in two staggered ranks (3 in front, 2 at rear) on a 25mm x 20 base
2 cavalry on 25mm x 20 base
2/3 dismounted cavalry on 25mm x 20 base
Two of my freinds on here like black powder for ACW so leon has made me 90mm sabot bases that will take 3 of the F&F bases. I also have a few 30mm wide sabot bases for a single F&F base to make up large units for Black powder
My aim in life was to P*ss off one person a day. I am so far ahead of schedule I will have to live to 97 even if I stop now.
hammurabi70
Reply #14 on:
26 September 2020, 06:36:23 PM »
As an aside, are bases normally too square? By this I mean that if a musket battalion was 200 hundred files in 3 ranks should the basing be nearer 2cms by 20cms and the rules reflect this?
www.olivercromwell.org
6mm wargames group:
6mm@groups.io
Pages:
1
2
« previous
next »
Please select a destination:
Welcome
=> Forum Info
=> Intro's and Welcomes
=> Requests
Wider Wargaming
===> 20th Century
Pendraken News & Info!
=> Shows
=> Photos
Wider Wargaming
===> Fantasy & Sci-Fi
=> Rules
Non-Wargaming Discussion
=> Chat & News
Wider Wargaming
=> General Discussion
=> General Pendraken
=> Fun Stuff
Wider Wargaming
=> Painting & Modelling
===> Painting Diaries
=> Batreps
===> Clubs/Societies
===> Sport
Wider Wargaming
===> Dungeons
=> Books
===> Scenics
=> New Figure Previews
=====> 2010 Show Stuff
Archive
===> PPC 2011!
===> WW2 Requests
===> WW1-SCW Requests
===> Fantasy/Sci-Fi Requests
===> Fantasy/Sci-Fi Photos
===> WW2 Photos
===> WW1/SCW Photos
Archive
=> Competitions
Welcome
===> In the Line of Fire!
Minibits Topics
=> General Minibits
Wider Wargaming
=> Resources
=====> 2011 Show Stuff
=======> 2010 & 2011 Previews
Archive
===> PPC 2012!
===> 18th Century Requests
Wider Wargaming
===> Blogs
Archive
Wider Wargaming
===> Downloadable Rules
===> Resources - 20th Century
Archive
=> The Big Move
=====> 2012 Show Stuff
Archive
===> PPC 2013!
=======> 2012 Previews
Wider Wargaming
=> Non-Pendraken Stuff
=====> 2013 Show Stuff
=======> 2013 Previews
Archive
===> PPC 2014!
===> Smoggy '13!
Pendraken Rules!
=> Warband
=======> 2014 Previews
=====> 2014 Show Stuff
Archive
===> PPC 2015!
===> Post-War/Modern Requests
Wider Wargaming
=> Genre/Period Discussion
=> Networking
Pendraken Rules!
=> Cold War Commander
===> BKC-III
=> Future War Commander
=> New Releases
=======> 2014 Releases
=======> 2013 Releases
=======> 2012 Releases
=======> 2010 & 2011 Releases
Archive
=> Battleground
===> Battleground 2015!
===> Old Newsletters
=====> 2015 Show Stuff
=======> 2015 Releases
===> Previous Years
===> Previous Years' Releases
===> Previous Years' Previews
=======> 2015 Previews
Archive
===> PPC 2016!
===> Battleground 2016
===> Pendraken Website Photos
=====> 2016 Show Stuff
=====> 2016 Releases
=====> 2016 Previews
Pendraken Rules!
=====> BKC-III Rule Queries
=====> BKC-III Miniatures
=====> BKC-III Battles
Archive
===> Battleground 2017!
===> PPO 2017!
=====> 2017 Releases
=====> 2017 Previews
=====> 2017 Show Stuff
===> Post-War/Modern Photos
Archive
===> PPC 2018!
===> Battleground 2018!
=====> 2018 Show Stuff
=====> 2018 Releases
=====> 2018 Previews
=====> Older Releases
=====> Older Previews
Pendraken Rules!
=> Blitzkrieg Commander IV
===> BKC-IV Rule Queries
===> BKC-IV Miniatures
===> BKC-IV Battles
===> BKC-IV - Army Lists!
Archive
===> Battleground 2019!
=====> 2019 Show Stuff
=====> 2019 Releases
=====> 2019 Previews
Wider Wargaming
===> Proxy Figures/Models
===> Scams & Spams
=====> 2020 Show Stuff
=====> 2020 Releases
=====> 2020 Previews
=> Painting Competition 2021!
Loading...
