Early Imperial Romans
Started by Duke Speedy of Leighton, 21 July 2020, 11:40:12 PM
Trajanic to be closer. A commission in 10mm Pendraken by Si Hall, the author of Mortiem et Gloriam. Shield transfers made to size by the Baggage Train.
Legio I
Deployed in close order
Deployed in loose order
A blurry Legio II
Rear view
Legio III (needs attached artillery)
Sudden craving for a 10mm Asterix!
Legio IV, also in need of artillery!
Note the subtle shield variation from Legio III
Must mark up that last base
The might of 204 legionary figures!
Top view - just realised it's about 107.7089123 per man to a real legion here!
Good grief, Will !  :o
Stonking work !  :-bd
monkeynut
Just brilliant! Lovely looking set of figures.
That is quite the mass of troops! Lovely work
Adamwest
Lovely especially the green legion, green romans aleays remind me of Asterix for some reason!
Quote from: Adamwest on 22 July 2020, 11:47:02 AM
Green tunics, blue shields
That's Legio V colours sorted then...
Course the 'istoric info is RED !
Late Republic shields may have been colour coded by cohort, Late Empire shields are a variety of colours. Those Early/ Mid Imperial shields we have found are all, or at least mainly red but I'm not convinced that means they all were. The Dura Europos shields are very fancy and may have been parade rather than field issue .... or may not :)
Like most of Ancient History, we have lots of very educated guesses but very few certainties!
I just went with what the Baggage Train would print for me guv
Steve is a bit of a Roman fan
Quote from: mad lemmey on 22 July 2020, 06:20:07 PM
Did you have to cut out a hole for the shield boss(es) in the transfers (?), Will ?
With luck, I might have time to get the paints out again, soon.....and I've fancied having a go at some of these chaps.
Cheers - Phil  :)
