Remembering the Korean War - 70 years on
Started by Sunray, 22 June 2020, 09:09:52 AM
There are some familiar piccies there, without doubt, Nobby ! :)
Sunray
Quote from: Techno on 23 June 2020, 09:39:38 PM
Yes, that's the 41 mob doing what they did best.   You captured their professional  elan  to a tee Phil.
Filipinos in Korea
A series of battles were fought over Hill Eerie from March to July 1952 by the Philippine 20th Battalion Combat Team approximately 2 miles (3.2 km) northeast of the more famous Pork Chop Hill
@Paulr  :-bd
That Kiwi 25pdr battery made ts way onto my table.  :D
Quote from: paulr on 23 June 2020, 10:33:33 PM
Kiwis in Korea
How much do each of the shells weigh ?
I'm trying to work out whether I might just be able lift a full box of eight of them.
(When I was younger, anyway.....I'm sure I wouldn't be able to now !)
Quote from: Techno on 24 June 2020, 07:50:42 AM
Sorry. Are you asking how much the shells of a 25pdr gun/howitzer weight?
Hi Nobby ! ;)
Really would have helped, if I'd noticed your reference to 25 pdrs.  X_X
Answer me this, to clear it up in my mind, though.
25 pds......Is that the total weight of the shell......(before it's fired)....or just the 'nasty' bit that drops on the foe ?
No Nobby, it's just the bangy bit, for referance a 105 weighs 30 lbs. There is a reason gun bunnies are big lads.
Thanks, chaps...... :)
But that begs the question.....How much did the empty case weigh, if it had to carry 240lbs ?
10 ? 20 ? 30 lbs ?.....More ??
No wonder 'gun bunnies' were brawny lads ! :o
Phil - the projectile on a 25pdr is 25lb, the brass case is roughly 6-10  lb with up to 1 1/2 lb of cordite in it. The smoke/chemical shell and AP shot are different weights/masses, the carriers are lighter, and I think the AP shot is as well. The case is separate so that you can vary the charge to alter the range or speed up an A/T shot. If you look at the piccies you'll see that the NZ gun has no muzzel break, it was added to UK weapons for NWE to allow a "supercharge plus" for AT work. Near the gun position there should be a small fire to burn unused cordite, but cant see one in the picture of the NZ gun.
Sunray
Quote from: ianrs54 on 24 June 2020, 11:21:31 AM
In winter climes like Norway , (and no doubt Korea) cordite was handy for lighting fires if the Bialaddins were burnt out or left behind.  Gunners would trade it for fags.  Of course at night such illuminations need concealed.  But you can create good black out with a few phoncos.  Once Hexamine was introduced it killed off the second hand cordite trade.
I recall as a boy visiting with my grandmother, an elderly lady on the north coast of County Antrim.  She lit her fire every morning with cordite from the wreck of HMS Drake.
In the Balkans in the 90s, Brit units were still using "Benghazi burners" when the No12s were U/S.
