Size of 17 cent carriage
Started by Last Hussar, 21 June 2020, 08:55:14 PM
How big a base does SYW10 carriage need? What if only 2 horses?
JimLeCat
Mine is on an 80x30mm base, which gives about 5 mm spare front and back and a little more at each side (width of model is about 15-16mm).
If you took off the front pair of horses, it would fit on a 60mm base.
Jim
Typical - the counters I am using are 70mm long!
A carriage once cost 17 cents?! Phew, with inflation it would be at least a quarter today!
You know the drill.
Coat.
Door.
Sunjester has one I think he has used only 2 horses to fit into the RUB trays
O Dinas Powys
23 June 2020, 11:12:20 AM #6 Last Edit: 23 June 2020, 11:16:16 AM by O Dinas Powys
Quote from: Last Hussar on 21 June 2020, 08:55:14 PM
It'll go on a 60x40 with just the two horses.
I mounted my extra horses on a 40x20 to put up front if required.
Looks liek you've got a fair bit of width - I'm looking at a 60x30 base.
O Dinas Powys
Quote from: Last Hussar on 23 June 2020, 06:44:46 PM
I was just going to take a photo with a 30mm width base so you could see the space when I discovered I'd actually based it on a 60x30mm one (with 20mm extension)!  :-[
howayman
Were 7 years war limber horses in pairs or in single file? or did it depend upon nation?
Don't care - if the play test is ok, I'm doing Grand Prix racing in Paris 1665.  8)
O Dinas Powys
Quote from: Last Hussar on 24 June 2020, 12:35:58 AM
:o
=O =D>
8-} :O)
I salute your madness, sir!
Ace of Spades
What team will you play; Duc de Renault or the Prince de Peugeot? I have the 6hp Comte de Citroën almost finished!  :D
Rob
Well, that wasn't the answer I expected!
