22 October 2020, 06:38:17 PM
308689 Posts in 17951 Topics by 2265 Members
Latest Member: siredazirahk
| |-+  Painting & Modelling
| | | |-+  The Marvelous Miscellany of MMcV
Pages: 1 [2] 3 4 ... 16 Go Down Print
Author Topic: The Marvelous Miscellany of MMcV  (Read 10275 times)
Guest
« Reply #15 on: 30 May 2020, 09:44:23 PM »
Some really fun figures in the fantasy range. Props to Phil as I think he was the sculptor for them? Have a few more of the fantasy figures based and primed for when I fancy a "palate cleanser".
I'll get the rest of the pictures up later tonight or tomorrow hopefully. And maybe lay out some of my plans for the next little while (whether I end up sticking to them is another matter...)
To be fair....As far as the current fantasy ranges are concerned....... I, at least, 'prettied up' and converted every single figure....Though I did make a good few newies/new bits for each of the ranges.
The only 'army' that was virtually all my own work was the dragonmen.
Very pleased that you're enjoying the ranges !....I had a lot of fun doing them.
Looking forward to the next batch of photo's. Thumbs up
« Reply #16 on: 30 May 2020, 11:09:08 PM »
Next up we're taking a bit of a diversion into another scale and looking at my 2mm forces for the British and some Turkish allies in the Crimean War. I'm fairly sure I've another 10 or 15 bases of these in a box with the start of the French army but there's enough here to get the gist. I also have around 50 bases of Russians to prime and paint at some point and the French to assemble. All in all, should have enough to cover most of the BBB Crimean War scenarios.
Infantry commanders:
Light infantry/skirmishers:
The single line is for veterans, the double line standard infantry:
The Turks in the back:
Artillery, cavalry and general:
« Reply #17 on: 30 May 2020, 11:28:50 PM »
And finally we travel to Mexico for some of the glorious Aztec range. These models are beautifully sculpted and a joy to paint given the detail and opportunity for colour. I fear I don't do them justice.
In the one's below I've picked a colour theme for each group but I have some more awaiting finishing touches that are a riot of colour and will be adding even more units soon.
Skirmishers:
Eagle and Jaguar Warriors:
The atlatl thrower on the small base is a shock missile marker.
City infantry with attached hero marker:
Some "wargamers eye view" shots:
Close-ups of the markers, some of these came out a little darker than I'd hoped but the heroes have face paint and tattoos:
And these poor sods who were mangled in the name of casualty markers:
« Reply #18 on: 30 May 2020, 11:41:14 PM »
That's all the pictures I have so far, other than this:
"What is that?" I hear you cry in disgust.
On another thread recently I was discussing different ways to make a battle board with an embedded grid. This is experiment 1. Someone suggested the clever idea of using tile spacers, so I've made a small grid using them and will add some paint and flock soon to see how it looks. It'll obviously be a little warped on the thin card but that's fine for the experiment. I did use a fairly lightweight filler here which may not work as well but will see once fully set.
So I'll be tracking any progress on that here as well as future updates on the existing projects, such as the large crusades expansion, more adventures in Mexico, those 2mm Russians and French and some new projects that might join the queue as I recently got the seeds of as Early Imperial China project and a Trojan War project. I've also some ideas and figures based around a 20th-century alt-history project, a 15mm Japanese myth HOTT army or two, plus a load of 32mm zombies. So quite a few different bits to play around with!
« Reply #19 on: 31 May 2020, 04:06:47 AM »
Och, it's the dreaded porridge monster the noo! Man the sporrans and load the usquabaugh! All cabers on deck!
Guest
« Reply #20 on: 31 May 2020, 08:02:59 AM »
Cracking work, again, Matthew !  Thumbs up
The Aztecs were also fun to do......Apart from those s*dding back banners. I don't want to see Wink.......There was an awful lot of bad language when I was doing those. At wits' end
Be interesting to see how the battle-board comes out. From the 'experiment' it looks like you're definitely on the right lines. Smiley
ianrs54
« Reply #21 on: 31 May 2020, 08:34:38 AM »
All looks good to me.
« Reply #22 on: 31 May 2020, 09:31:38 AM »
Thanks!
I must say I have found trying to attach the banners pretty frustrating, though have done suggestions to try for the next batch to make it easier.
mad lemmey
Marquis
« Reply #23 on: 31 May 2020, 10:35:20 AM »
Very cool work there
Off to the Shed of Decency.
« Reply #24 on: 31 May 2020, 11:41:50 AM »
Added some brown paint to the porridge monster. The tile spacers aren't too clear currently but hopefully once dry and drybrushed over they'll become more apparent.
Got a bunch of sample brown wall paints in a bargain bucket last year on the basis I'd use them for something like this at some point.
« Reply #25 on: 31 May 2020, 01:04:32 PM »
Och, somehow a chocolate porridge monster isnae so intimidatin'!
« Reply #26 on: 31 May 2020, 02:12:52 PM »
Looks like single spacers just get lost, tried dry brushing and washes but still not clear enough. Have stuck a couple on top of the hidden ones to see if I can blend them in but still stand out.
Also going to try with sticking a couple together then doing it to see if they stand out more after the filler.
hammurabi70
« Reply #27 on: 31 May 2020, 06:27:49 PM »
Special created for Bloody Big Battles usage or for the Crimean War [in Crimea or the Baltic]?
« Reply #28 on: 31 May 2020, 08:18:08 PM »
Primarily built around the various BBB scenarios, though I'm sure they'll see service elsewhere in time.
« Reply #29 on: 31 May 2020, 08:28:17 PM »
Some more experiments for the board here. Added some tile spacers on top of the ones hidden by the filler and flocking around them. Looking a bit better. Also tried a couple with various bits below the flock to create small mounds.
At the top left I've tried with doubled spacers and waiting some bits to dry. May need another layer of flock.
To the right of that I've hidden a magnet under the flock and have a small clump on ferrous paper drying to see how it works.
Pages: 1 [2] 3 4 ... 16 Go Up Print
