20 October 2020, 04:02:52 AM
308533 Posts in 17944 Topics by 2265 Members
Latest Member: siredazirahk
| | |-+  Need Help/Advice/Guidance with 10mm Basing
Pages: 1 [2] Go Down Print
Author Topic: Need Help/Advice/Guidance with 10mm Basing  (Read 1032 times)
« Reply #15 on: 12 May 2020, 02:07:12 AM »
Thanks again, everyone!
My vehicles are already based, so I'm sticking with that (as well as to match the infantry, as I wrote above), and I'm already past using clear bases.
The question, at this point, is whether I can use one set of bases that is either suitable for summer and winter or can easily be transitioned between the two, or use two sets of bases and pry them off/stick them off as needed.  It's looking like the latter, so another order out to Leon Wink
hammurabi70
« Reply #16 on: 12 May 2020, 03:38:06 PM »
What do you ‘stick’ with?
« Reply #17 on: 13 May 2020, 02:01:01 AM »
A glue called E6000, which holds well but I'm still able to pry minis off relatively easily with a knife.
O Dinas Powys
Blowing up a storm!
« Reply #18 on: 13 May 2020, 04:52:10 PM »
Maybe, after the first pry, attach some magnets: stick one to the base, then attach the second under the vehicle with a blob of Milliput to bridge the gap  Undecided
(I know, even though it's fantasy  Shocked  Wink  )
Pages: 1 [2] Go Up Print
