Welcome,
Guest
. Please
login
or
register
19 April 2021, 04:41:05 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Check our
2020 Releases Summary
to see f you've missed anything!
321971
Posts in
18517
Topics by
2312
Members
Latest Member:
Zookie
Wider Wargaming
Painting & Modelling
(Moderator:
Head swapping
« previous
next »
Pages:
1
2
Author
Topic: Head swapping (Read 1734 times)
Re: Head swapping
Reply #15 on:
30 April 2020, 02:37:05 PM »
Quote from: ianrs54 on 30 April 2020, 11:55:07 AM
I trust you are aware that super glue was designed for sticking up bullet wounds. The fumes, particularly with the cheap pound land stuff can cause damage to your eyes.
Off-the-shelf consumer superglues are not suitable for medical use, because they are not formulated to reduce toxicity and prevent foreign body reactions, as would be the case with medical cyanoacrylates.
Also, they glue your fingers to the table, if you're not careful!
Re: Head swapping
Reply #16 on:
30 April 2020, 03:44:20 PM »
Quote from: chrishanley on 29 April 2020, 11:55:09 AM
In an attempt at making Indian figures for my 14th army I must swap the heads on a few figures, notably to create turban headed bren gunners. Has anyone got any advice before I get straight in and make a another pigs ear?
I find it easier to do a hat swop sometimes. With a heavy bladed scalpel, No 24 blade or similar, you can pare off a headdress without losing too much metal. The bond is also much stronger than that with a head because the surface area is comparatively bigger. I've had superglued heads come off in the past, but never a superglued hat.
Superglue depends on moisture to cure and there is usually enough in the surfaces of most joints to do this. So it cures better, and faster, on days of high humidity than on others, and that is why it bonds skin so well!. But, very small joints often don't have enough residual dampness. To give it a hand I find that touching the joint with the tip of my tongue helps (MAKE SURE YOU DO THIS BEFORE YOU APPLY THE SUPERGLUE!), even just breathing on the joint helps too. Alternatively a squeezable spray bottle of water will do the job.
You might also consider using a spray superglue accelerator, specifically intended for the purpose. For all super-glue applications I use a spray accelerator these days. The bond is instantaneous and any residue accelerant evaporates in seconds. You can use also baking powder but I find it too messy for use with small jobs and too dangerous with large ones - it gets hot, enough to burn. If you need a filler try mixing superglue with baby talc.
Last Edit: 30 April 2020, 04:20:13 PM by John Cook
Thread Derailment Specialist
Re: Head swapping
Reply #17 on:
30 April 2020, 09:00:19 PM »
Quote from: Orcs on 29 April 2020, 10:01:33 PM
Be careful not to get super glue and baking soda together on your fingers - it has quite a hot thermic effect. - I know
I suppose I ought to give you all a laugh about how I know.
I had cut myself with the scalpel. My normal trick with this to stop it bleeding and allow me to carry on without coating stuff in blood is to put a blob of superglue over the cut. However this time I had done a
"Real Techno
", and it would not go off fast enough to stop the bleeding. Having read on this forum how Baking Soda cures superglue instantly I have a small pot of it on my painting table.
Being an engineer I worked out that if I put a blob of superglue on the cut followed by a light dusting of baking powder I could stop the bleeding........ not being a chemist I did not work out the chemical reaction would be to produce a very hot thermic effect, causing me to run to bathroom shouting "F***,F***,F***! to put my finger under the cold tap.
The worst bit though was explaining to a concerned Mrs Orcs who had come upstairs to see what my shouting was about. Her concern very quickly to mirth at my expense.
My aim in life was to P*ss off one person a day. I am so far ahead of schedule I will have to live to 97 even if I stop now.
Guest
Re: Head swapping
Reply #18 on:
01 May 2020, 07:37:43 AM »
Well....It made
me
laugh !!
Do you want some of those plasters back, Mark ?.....I've still got a few.
Terry37
Re: Head swapping
Reply #19 on:
04 May 2020, 04:32:07 AM »
One I have removed the original head I make sure he neck is flat for receiving the new head. Then I drill a hole in the neckand make a peg on the bottom of the new head to fit in the hole. This makes for a stronger bond.
Terry
Pages:
1
2
« previous
next »
Please select a destination:
Welcome
=> Forum Info
=> Intro's and Welcomes
=> Requests
Wider Wargaming
===> 20th Century
Pendraken News & Info!
=> Shows
=> Photos
Wider Wargaming
===> Fantasy & Sci-Fi
=> Rules
Non-Wargaming Discussion
=> Chat & News
Wider Wargaming
=> General Discussion
=> General Pendraken
=> Fun Stuff
Wider Wargaming
=> Painting & Modelling
===> Painting Diaries
=> Batreps
===> Clubs/Societies
===> Sport
Wider Wargaming
===> Dungeons
=> Books
===> Scenics
=> New Figure Previews
=====> 2010 Show Stuff
Archive
===> PPC 2011!
===> WW2 Requests
===> WW1-SCW Requests
===> Fantasy/Sci-Fi Requests
===> Fantasy/Sci-Fi Photos
===> WW2 Photos
===> WW1/SCW Photos
Archive
=> Competitions
Welcome
===> In the Line of Fire!
Minibits Topics
=> General Minibits
Wider Wargaming
=> Resources
=====> 2011 Show Stuff
=======> 2010 & 2011 Previews
Archive
===> PPC 2012!
===> 18th Century Requests
Wider Wargaming
===> Blogs
Archive
Wider Wargaming
===> Downloadable Rules
===> Resources - 20th Century
Archive
=> The Big Move
=====> 2012 Show Stuff
Archive
===> PPC 2013!
=======> 2012 Previews
Wider Wargaming
=> Non-Pendraken Stuff
=====> 2013 Show Stuff
=======> 2013 Previews
Archive
===> PPC 2014!
===> Smoggy '13!
Pendraken Rules!
=> Warband
=======> 2014 Previews
=====> 2014 Show Stuff
Archive
===> PPC 2015!
===> Post-War/Modern Requests
Wider Wargaming
=> Genre/Period Discussion
=> Networking
Pendraken Rules!
=> Cold War Commander
===> BKC-III
=> Future War Commander
=> New Releases
=======> 2014 Releases
=======> 2013 Releases
=======> 2012 Releases
=======> 2010 & 2011 Releases
Archive
=> Battleground
===> Battleground 2015!
===> Old Newsletters
=====> 2015 Show Stuff
=======> 2015 Releases
===> Previous Years
===> Previous Years' Releases
===> Previous Years' Previews
=======> 2015 Previews
Archive
===> PPC 2016!
===> Battleground 2016
===> Pendraken Website Photos
=====> 2016 Show Stuff
=====> 2016 Releases
=====> 2016 Previews
Pendraken Rules!
=====> BKC-III Rule Queries
=====> BKC-III Miniatures
=====> BKC-III Battles
Archive
===> Battleground 2017!
===> PPO 2017!
=====> 2017 Releases
=====> 2017 Previews
=====> 2017 Show Stuff
===> Post-War/Modern Photos
Archive
===> PPC 2018!
===> Battleground 2018!
=====> 2018 Show Stuff
=====> 2018 Releases
=====> 2018 Previews
=====> Older Releases
=====> Older Previews
Pendraken Rules!
=> Blitzkrieg Commander IV
===> BKC-IV Rule Queries
===> BKC-IV Miniatures
===> BKC-IV Battles
===> BKC-IV - Army Lists!
Archive
===> Battleground 2019!
=====> 2019 Show Stuff
=====> 2019 Releases
=====> 2019 Previews
Wider Wargaming
===> Proxy Figures/Models
===> Scams & Spams
=====> 2020 Show Stuff
=====> 2020 Releases
=====> 2020 Previews
=> Painting Competition 2021!
=> The Bigger Move!
Loading...
