New Scenario Book for Sellswords and Spellslingers
Started by sunjester, 10 April 2020, 10:41:08 PM
I've just heard that my mini-campaign book for Sellswords and Spellslingers, LAST STAND AT MISTHAM, is now due for publication before the end of summer!  ;D
A brief post on my blog http://grahamsgaming.blogspot.com/2020/07/scenario-book-for-sellswords.html
 =D> =D> =D> =D>
I hope it is popular so you get to do some more books
Thank you very much gentlemen.  :D
Raider4: There will be some new foes and accompanying cards.
ronan
I've just discovered S & S a few days ago and started to play (solo)
( I'm an old fan of SoBH)
So I'm glad I will (soon ?) be using your scenarios !
Thanks for the work !
Quote from: sunjester on 15 July 2020, 06:28:52 PM
Nice to see.
Although I have literally just finished the last of the cards that come with the rulebook. Tedious stuff, printing out, glueing backs to fronts and trimming them up. Look good once done though, so it's probably worth it. Not looking forward to doing some more mind.
Tip: If you're making lots of cards for anything, get one of these - the cards look so much more polished & professional with rounded corners.
Quote from: Raider4 on 17 July 2020, 10:51:52 AM
... or get a pack of card sleeves, as used by serious collectable card game players, a pack of cheap playing cards and the fronts and slide a front and a random playing card into the sleeve. If v2 comes out and has different cards remove the front and replace with the new version. Simples!
Home made cards in action
ronan
I should have used sleeves !  :(
I agree with sunjester, and i would have use a less polite word   ;D
Quote from: Ithoriel on 17 July 2020, 01:35:56 PM
There's an idea, although note that S&S cards are tarot-sized, slightly longer than regular playing cards.
Quote from: Raider4 on 17 July 2020, 05:23:27 PM
There's a larger card (bottom of the picture) which is in a tarot card sleeve.
I sleeved the cards from "Call to Adventure" which are tarot sized.
There are a plethora of different sleeve sizes and designs.
I like the Dragon Shield clear ones though there are some other manufacturer's sleeves with designs on the back which look a bit swizzier.
