Welcome,
Guest
. Please
login
or
register
19 January 2021, 05:30:59 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Our
Peninsular Napoleonic
project is complete, updates coming soon!
314477
Posts in
18210
Topics by
2277
Members
Latest Member:
Chalace
Requests
Irregular Wars "Stuff"
« previous
next »
Pages:
1
2
3
4
Author
Topic: Irregular Wars "Stuff" (Read 4808 times)
Re: Irregular Wars "Stuff"
Reply #45 on:
25 April 2020, 07:11:26 PM »
It's been a long time...
So here's a summary of "existing ranges that you can use".
After splitting the world and dividing the lists into "theatres", I've decided to focus on my favourite proto-colonial setting.
The Indian Ocean in the century or so following Da Gama's rounding the cape.
This can involve:
Portuguese
Hollanders
Tribal African
West African
Arab
Moghul
Rajput
Vijayanagara
East Indies
Eastern Pirates.
You can push your luck a bit and shoehorn in:
Ottomans (In East Africa)
Savafid Persians (Ormuz and Persian gulf)
Ming Chinese
Japan
Korea
I'mm concentrate on the core nations for now.
Portugal and Hollanders
can be supplied forom the Renaissance ranges.
I've a feeling that the wealthier members of expeditions could be supplied by the League of Ausberg command packs.
Both have a range of colonial allies - Headhunter / Blowpipe native scouts are the only notable gap.
Tribal Africans
probably need to be Zulu with some mixed in Masai.
I cannot find archer or matchlock figures to fill out the shooter roles.
Probably use a chieftain as a shaman.
East Africans
Tend to be civic (Potential form Ottoman and Arab ranges) or Tribal - Mahdists provide a contrast to the usual Zulu fighters.
These have the heavy lancer option (I think classical cataphracts and a bit of work will fit the bill).
Arab
Dark Age Arabs and some azab figures form Renaissance Ottomans will fit the bill.
Moghul, Rajput, Vijayanagara
These three Indian powers have a lot of common components.
The foot units of the Indian mutiny range provide levy, swordsmen and matchlocks. Archers are absent, Arab figures, (Or classical Indians) might be substituted.
Elephants from the Mutiny range, otherwise it's about making the best of the classical indians again.
Imagination is required for the disnctive mounted components.
The Ottoman range provide something suitable for Moghul riders.
Cataphracts (Classical again) might be the best stand-ins for Rajput lancers.
For artillery, take your pick from large Western style pieces, or old Ottoman bombards.
East Indies
It's tricky to match the warrior garb of sarong, long shield, turban and kris / javelin - some artistic license required here.
Most available figures with Turban are pretty well wrapped up aganst the sun, most with loincloths are distinctly sub-saharan.
Mahdist horse might make the best match for the sultans cavalry.
Elephant will be an Indian Mutiny range.
The difficulty in finding blowpipe scouts is noted above.
Eastern Pirates
Quite a variety here, I tend to visualise these as the Bugis or Sulu, so would expect a very East Indies appearance.
With less focus on sarong and long shield you may be able to co-opt some Indian mutineers and Arabs.
If you're prepared to base your pirates a bit further North, you can throw in some Japanese - thought I'd go for the peasant figures as opposed to the more distinctive samurai and ashigaru.
Conclusion:
Pendraken certainly provide plenty of figures to enable Portuguese and Dutch explorers to fight encounters in South Africa, East Africa, Arabia and all of India.
It's a bit of a push to provide forces for the East Indies.
I'm all ears!!
Reply #46 on:
25 April 2020, 08:55:18 PM »
Good list of proxies. For Tribal African archers you could look at Aztec commoner with bow.
You could also use the rugga rugga for arquebusiers.
You mention West and East Africans but since you mention heavy cavalry I'll assume you mean West. East Africans wouldn't have cavalry but would be a heavily Arabisised elite with tribal auxiliaries. Both covered by other proxies. You could also look at the Sudanese Ghulam types from the Arab range
You could have a look at the newer Sarmatian cataphracts for heavy cavalry
The East Indies are a problem. Long shields are for more primitive types like dyaks so maybe Indians could be used. Turbans aren't worn by all and sometimes trousers are worn with the sarong and if the weather drops down to a chilly 30 degrees shirt and bolero could be worn. I'd use a big mixture, almost like your described pirates. Not much to suggest for the blowpipe type, maybe the Sudanese javelinman from the Arab range with the spearhead snipped off the javelin set in amongst a lot of greenery 🙂
Probably not much of a help but good luck.
Reply #47 on:
25 April 2020, 11:29:52 PM »
The Arab cavalry from the new Persian range (PER13) looks pretty versatile. I've a pack of them in my painting queue to add to my medieval Saracens. But they'd potentially fit as some irregular cavalry for your period:
https://mmcvhistory.home.blog/
Reply #48 on:
26 April 2020, 06:52:37 PM »
Thanks, some great suggestions there.
I think where it's difficult to match an infantry type, employing a mixture of "near enough" types provides a a better look than using all one single type.
TinyTinTroops
Reply #49 on:
29 June 2020, 08:05:36 PM »
We've been messing around with these rules a fair bit over the past year or two but never really did much with the original period of the rules.
I had a number of left over ECW & late 17C stuff from other projects and hit on the rules as a simple way of using them up and having short games in periods we didn't do. Almost skirmish but not quite meant that we could push boundaries & reality a bit.
We decided very quickly that we would update the rules to work from about 1660 on to about 1720 and concentrate on the Americas. We ditched all the silly stuff such as parsons and priests and the random army lists - I can see how others would like them but we don't.
To cut a long story short we ended up extending them to the FIW as well and now we both have quite a lot of varied forces for Spanish, English (later British), French, American, Pirates, Cimmaroons, Woodland Natives etc. I've got a pile of Conquistador & S. American stuff yet to paint - taking us back to the rules without our additions/changes. We have just started a simple campaign in the FIW and the battles will be fought using our version of IW.
You could look at some Irregular Miniatures stuff for pre-gunpowder American Natives and they also do a quite varied pack of Pirates. Similar in size to Pendraken but more loosely sculpted.
Tony Hughes of Tiny Tin Troops
2016 Painting Competition
- Runner-Up!
Reply #50 on:
30 June 2020, 09:35:41 AM »
Quote from: TinyTinTroops on 29 June 2020, 08:05:36 PM
... Cimmaroons ...
Cameroons
2018 Painting Competition
- Runner-Up!
Reply #51 on:
30 June 2020, 11:20:30 AM »
Period term for escaped slaves and others living outside the law. They could be quite organised and large in number.
2011 Painting Competition
- Winner!
2012 Painting Competition
- 2 x Runner-Up!
- Runner-Up!
2017 Paint-Off
- 3 x Winner!
Reply #52 on:
30 June 2020, 06:38:55 PM »
Quote from: fred. on 30 June 2020, 11:20:30 AM
Cimarons: Got the best riddims.
The Camerons are a whole different fearsome clan:
Cameroons - deadly in the box.
And don't get me started with:
TinyTinTroops
Reply #53 on:
30 June 2020, 09:21:21 PM »
It is in the army lists and refers to escaped slaves who have banded together, often allying themselves with the local native peoples in resisting the Spanish.
Originally it seems to have referred to their ferocity in defending their settlements - it is also a Spanish name for the wild sheep of the mountains who can get very aggressive to people during the rut.
It is spelled in various ways and became a term sometimes applied to independent African communities in non-Hispanic areas too.
Despite its similarity to other Spanish terms relating to race it doesn't seem to have originally been a derogatory name.
- Runner-Up!
Reply #54 on:
01 July 2020, 03:40:53 AM »
Thanks Fred & TTT, learnt something today
- Runner-Up!
Pages:
1
2
3
4
« previous
next »
Please select a destination:
Welcome
=> Forum Info
=> Intro's and Welcomes
=> Requests
Wider Wargaming
===> 20th Century
Pendraken News & Info!
=> Shows
=> Photos
Wider Wargaming
===> Fantasy & Sci-Fi
=> Rules
Non-Wargaming Discussion
=> Chat & News
Wider Wargaming
=> General Discussion
=> General Pendraken
=> Fun Stuff
Wider Wargaming
=> Painting & Modelling
===> Painting Diaries
=> Batreps
===> Clubs/Societies
===> Sport
Wider Wargaming
===> Dungeons
=> Books
===> Scenics
=> New Figure Previews
=====> 2010 Show Stuff
Archive
===> PPC 2011!
===> WW2 Requests
===> WW1-SCW Requests
===> Fantasy/Sci-Fi Requests
===> Fantasy/Sci-Fi Photos
===> WW2 Photos
===> WW1/SCW Photos
Archive
=> Competitions
Welcome
===> In the Line of Fire!
Minibits Topics
=> General Minibits
Wider Wargaming
=> Resources
=====> 2011 Show Stuff
=======> 2010 & 2011 Previews
Archive
===> PPC 2012!
===> 18th Century Requests
Wider Wargaming
===> Blogs
Archive
Wider Wargaming
===> Downloadable Rules
===> Resources - 20th Century
Archive
=> The Big Move
=====> 2012 Show Stuff
Archive
===> PPC 2013!
=======> 2012 Previews
Wider Wargaming
=> Non-Pendraken Stuff
=====> 2013 Show Stuff
=======> 2013 Previews
Archive
===> PPC 2014!
===> Smoggy '13!
Pendraken Rules!
=> Warband
=======> 2014 Previews
=====> 2014 Show Stuff
Archive
===> PPC 2015!
===> Post-War/Modern Requests
Wider Wargaming
=> Genre/Period Discussion
=> Networking
Pendraken Rules!
=> Cold War Commander
===> BKC-III
=> Future War Commander
=> New Releases
=======> 2014 Releases
=======> 2013 Releases
=======> 2012 Releases
=======> 2010 & 2011 Releases
Archive
=> Battleground
===> Battleground 2015!
===> Old Newsletters
=====> 2015 Show Stuff
=======> 2015 Releases
===> Previous Years
===> Previous Years' Releases
===> Previous Years' Previews
=======> 2015 Previews
Archive
===> PPC 2016!
===> Battleground 2016
===> Pendraken Website Photos
=====> 2016 Show Stuff
=====> 2016 Releases
=====> 2016 Previews
Pendraken Rules!
=====> BKC-III Rule Queries
=====> BKC-III Miniatures
=====> BKC-III Battles
Archive
===> Battleground 2017!
===> PPO 2017!
=====> 2017 Releases
=====> 2017 Previews
=====> 2017 Show Stuff
===> Post-War/Modern Photos
Archive
===> PPC 2018!
===> Battleground 2018!
=====> 2018 Show Stuff
=====> 2018 Releases
=====> 2018 Previews
=====> Older Releases
=====> Older Previews
Pendraken Rules!
=> Blitzkrieg Commander IV
===> BKC-IV Rule Queries
===> BKC-IV Miniatures
===> BKC-IV Battles
===> BKC-IV - Army Lists!
Archive
===> Battleground 2019!
=====> 2019 Show Stuff
=====> 2019 Releases
=====> 2019 Previews
Wider Wargaming
===> Proxy Figures/Models
===> Scams & Spams
=====> 2020 Show Stuff
=====> 2020 Releases
=====> 2020 Previews
Loading...
