24 May 2020, 10:50:19 PM
299107 Posts in 17601 Topics by 2238 Members
Latest Member: Ave75
|-+  Pendraken Rules!
| | |-+  Ambushes and Field Defences
Author Topic: Ambushes and Field Defences  (Read 382 times)
Zypheria
« on: 29 November 2019, 07:54:04 PM »
I'm going to play a big battle (4000 points vs 6000) and I'm planning to use some ambushes against my enemies to delay the advance of their troops. The question is, Can I once revealed the 3 troops per Ambush deploy them inside Hasty Field Defences like trenches?
« Reply #1 on: 29 November 2019, 09:57:08 PM »
I would say yes, as long as it makes sense in the terrain they deploy in.
Moderator
« Reply #2 on: 29 November 2019, 11:18:00 PM »
I'd agree that Trenches could be included in the Ambush but only if the Trenches are deployed in cover.
You'd need to have bought the Trenches at the outset of the game. The points for the Trenches must fall into the % points allocated for hasty defense.
You can only have enough field defenses for the troops in the Ambush - no more.
No other types of defenses can be used in Ambush - that includes barbed-wire or minefields or gun pits or vehicle scrapes etc.
There might be an argument for a force like the Japanese (specifically) hiding dug-outs and maybe even pill-boxes in an Ambush but only in dense jungle.
Maybe even allowing something similar in the areas of rubble inside a large BUA of damaged buildings (such as Stalingrad or Berlin - for example). But these would need to be specifically agreed by all players at the start of a game or in a campaign or scenario setting. Also be careful of the visibility and proximity rules that trigger Ambushes in cover.
The way Ambushes work in the rules allows an appropriate degree of flexibility around their deployment and allocating field defenses into an Ambush might make what is already a very powerful games mechanism (especially with the attached artillery barrage rule) even more powerful. So I'd suggest you give it a go, and if you'd report back on how it worked, good or bad, and any unforeseen consequences, that would be greatly appreciated.
