25 May 2020, 05:15:50 AM
299125 Posts in 17601 Topics by 2238 Members
Latest Member: Ave75
|-+  Pendraken Rules!
| | |-+  BKC-IV Errata!
Pages: [1] 2 Go Down Print
Author Topic: BKC-IV Errata!  (Read 2918 times)
Viscount
« on: 14 November 2019, 10:46:05 PM »
After many months of discussion and tweaks behind the scenes, the Blitzkrieg Commander IV Errata sheets are finally here!  We've split the corrections into 2 separate pdf files, one for the rules themselves and one for the army lists.  With the rules errata, we've made sure to give the page number of the correction along with the sentence, paragragh or table that is being amended, to avoid any confusion over which word or number should be altered!  The lists errata is fairly self-explanatory although we're sure there will still be some areas which might be up for debate!
We've managed to address around 95% of the feedback and comments we've had since the launch, with the remaining 5% requiring a bit more thought and some playtests to see if a change is needed.  We'll continue to monitor the feedback as people play the game more and we can respond to any other queries as they come in.
No doubt there will be some queries on this, but please make sure to give the file a good read-through, along with the wider context in the rules document as well.  There has been a lot of back and forth on some of the points raised and in some cases there will be folks who like the fix that we've implemented while others prefer the original version.  As always with any set of rules, if you prefer to play a particular rule a certain way, and your friends/group/club are on board with that, then go for it!  The bottom line is to enjoy your games!
BKC-IV Rules Errata: http://bit.ly/BKCErrataMar20
BKC-IV Army List Errata: https://pendraken.co.uk/ProductImages/BKC-IVArmyListsErrata.pdf
Previous Errata: https://pendraken.co.uk/ProductImages/BKC-IVRulesErrata.pdf
« Last Edit: 04 March 2020, 11:31:44 PM by Leon » Logged
« Reply #1 on: 14 November 2019, 10:53:02 PM »
Thanks for all the work going into the BKC stuff.
« Reply #2 on: 14 November 2019, 11:29:26 PM »
Good job!!
T-Square
« Reply #3 on: 15 November 2019, 12:42:53 AM »
Yeehaw!   Grin
« Reply #4 on: 15 November 2019, 08:58:06 AM »
Quote
Well said Leon. I've always tweaked BKC to suit my view of things and it works for me, but not necessarily for others. Given the scale of this conflict, the various theatres, troops, weapons used etc, you cannot cover every possible situation. So a good dose of common sense will invariably resolve any 'issues' IMHO.
2017 Paint-Off - 2 x Winner!
Dr Dave
Guest
« Reply #5 on: 15 November 2019, 02:14:30 PM »
I notice now that, regardless of doctrine, for all it says: "When using (optional) Fixed Formations, HQs can only issue orders to units within their own formation."
In BKCIV it used to be:
Rigid: no orders from HQs across formations
Normal: orders from HQs across formations but with a -1 penalty
Flexible: orders from HQs across formations have no penalty.
Is the errata right?
Moderator
« Reply #6 on: 15 November 2019, 04:24:08 PM »
No - not an Errata, it is a Change.
In a Fixed Formation Game HQ's cannot order units outside their own formations regardless of their Tac.Doc.
CO's can, but subject to their Tac.Doc. may be subject to penalties (see below):
Tactical Doctrine - Page 74 Adjust table to read:
Normal Tac.Doc. •  When using (optional) Fixed Formations, HQs can only issue orders to units within their own formation.
The CO may issue orders to units in other formations, but will be subject to a -1CV command penalty when doing so.
Rigid Tac.Doc. •  When using (optional) Fixed Formations, HQs can only issue orders to units in their own formation.
Flexible Tac.Doc. •   When using (optional) Fixed Formations, HQs can only issue orders to units in their own formation.
The CO may issue orders to units in other formations without penalty when doing so.
Dr Dave
Guest
« Reply #7 on: 15 November 2019, 04:45:11 PM »
I didn’t see that change coming. It doesn’t seem to be all that reflective of German (flexible) as opposed to Russian (rigid) doctrine. Not much real difference bar what the CO can do. Seems to be an unnecessary change. Ho hum.
Prophaniti
« Reply #8 on: 15 November 2019, 09:20:36 PM »
Well.  I've had a good read and I like what I see.  Got to give the changes a go on the tabletop of course.
Moderator
« Reply #9 on: 16 November 2019, 06:22:30 PM »
Then, I would suggest that the answer would be to NOT use Fixed Formations, if you want your HQs to be able to order units in other formations.
Flexible Tac.Doc. has other benefits. Rigid has its own specific restrictions and advantages. There is a very subtle balance between CV and Tac.Doc. and a higher CV HQ in a Flexible.Tac.Doc. army already has significant advantages.
I'd also suggest that it was rare for even German formation commanders to order units in other formations, if the commander(s) of those other formations were still alive or in communication with their forces.
Matt1tibby
« Reply #10 on: 22 November 2019, 11:44:27 PM »
I’ve had chance to look at the BKC IV errata, and there are a few things that seem to be wrong in them, or is it just me?
1.   Page 1 - the reference to page 20, in the line above Profile Page 8, I think should be page 78 when it discusses Low Profile?
2.   Page 2 – Terrain, Target Unit Table-Page 15, that should be Page 13?
3.   Page 6 – Field defences table. I like the changes in this, but doesn’t it disagree with the Saves Table on page 36, and the Fortifications table at the bottom of page 11?
There are also a few typos which I haven’t detailed.
ianrs54
« Reply #11 on: 23 November 2019, 08:26:28 AM »
As its your first post Matt - goad moaning !
Dr Dave
Guest
« Reply #12 on: 23 November 2019, 11:15:46 AM »
Vehicle scrape has a save of "15" - Should say "5" right?
ianrs54
« Reply #13 on: 23 November 2019, 11:43:03 AM »
On a d6, I suspect so !
Count
« Reply #14 on: 23 November 2019, 03:22:09 PM »
Same from me, Matt....Welcome to the forum. Smiley
Pages: [1] 2 Go Up Print
