30 May 2020, 04:31:13 PM
299590 Posts in 17618 Topics by 2243 Members
Latest Member: Bookwizard
| |-+  Rules
| | |-+  Basing help for Rommel
Author Topic: Basing help for Rommel  (Read 1035 times)
Dr Dave
Guest
« on: 06 October 2019, 12:20:18 PM »
So I've played BKC for years and years. All of my North Africa stuff is based on mdf, 2mm thick. Occasionally I want to play Rommel. These really require unit stats on the base. So I tried post-it notes cut to size with a cm or so sticking out the rear edge to record the strength / type of unit etc. It was OK but not as robust as I'd like. Ideally I'll like thick card on the back edge with the relevant details showing. So I was thinking of a crap glue (like post its) that leaves no residue so I can bin the "stat. card" base and go back to BKC as and when.
Has anyone used anything like this? Is there a better way?
ianrs54
« Reply #1 on: 06 October 2019, 12:23:04 PM »
2 small holes in the back, and add cocktail sticks with stats on a banner might work
« Reply #2 on: 06 October 2019, 12:36:38 PM »
Could you mount them on a sabot base, with the stats on this?
2017 Paint-Off - 2 x Winner!
« Reply #3 on: 06 October 2019, 01:04:15 PM »
Copydex
« Reply #4 on: 06 October 2019, 01:34:36 PM »
What I do is print the stats on to normal paper, in a strip about 7-10mm deep, then cut these out, leaving a generous amount of paper to go under the base. Then I use prit-stick to glue the labels in place. This holds well for a game, and can be removed pretty easily afterwards.
I do something similar for FKaP.
T13A
Captain
« Reply #5 on: 06 October 2019, 02:23:11 PM »
Hi Dave
Whenever I have to use labels on the back of bases I use MS excel for the label itself, print off on thin card, cover with see through sticky back plastic (yes, I did watch Blue Peter back in the day) and attach to the base with a small piece of something called 'Invisible Tape' from Tesco. I also put a bit of gloss varnish on the underside of the base just where I attach the label this helps a lot when peeling the label off. The sticky back plastic on the label means I can use non-permanent pens to mark off 'hits' etc and simply wipe off and use them again and again. Hope that helps.
Cheers Paul
« Reply #6 on: 06 October 2019, 10:40:46 PM »
Blu-tack
« Reply #7 on: 06 October 2019, 11:11:15 PM »
Blu-tack
Thats the stuff...relabelled half the Covenanter army units l used in our last game in about 5 minutes by just blu-tacking pre-prepared labels on them.
......."We'll go with what we've got"
hammurabi70
« Reply #8 on: 12 February 2020, 02:35:55 PM »
So what did you finally do?  We tend to use off-table sheets as the stats are rapidly learnt and remembered so we just need to mark the casualties.
« Reply #9 on: 12 February 2020, 06:23:25 PM »
Are stamp hinges still a thing?
Dr Dave
Guest
« Reply #10 on: 12 February 2020, 07:36:59 PM »
What did I do?
Laminated cards with the stats protruding out from under the base. Mark off the casualty boxes with a whiteboard marker. Lose the “card” for bkc games.
hammurabi70
« Reply #11 on: 12 February 2020, 07:54:40 PM »
What did I do?
Smart move.  We use micro dice to mark the casualties but the laminated card is a trick worth remembering.  BKC are not rules for my taste so the dilemma does not arise.
« Reply #12 on: 12 February 2020, 09:50:12 PM »
I've been planning to experiment with magnets for armies with multiple rule sets, have some magnetic tape I found on eBay that's about the thickness of a 2mm MDF base that I think will work well for labels combined with some ferrous paper.
