Maths Problem
Started by fsn, 05 August 2019, 08:21:05 AM
The original question was concerning a 1:1 ratio, so 600 real men and 600 pendraken figures, anything else and you don't have 1:1 ratio.
The size of the figures has nothing to do with it, other than measuring out how much space 600 Pendraken figures need (double ranked, just like the real unit').
Quote from: Last Hussar on 05 August 2019, 10:49:41 PM
Distance eyes to crown is 4"/10cm. That's less than a mm on Pendraken figure.
But not when you add a Shako etc.
I was curious about that also, LH. Nearly 17% of a Pendraken figure's height would be forehead! It made me think of UFO's  :P
fsn, as you'll be doing Scottish Flodden stuff, the formula for calculating the number of ranks and files for a given number of men is here:
http://forum.milua.org/archive/TactiqueUk.htm
James IV had an app on his smartphone for this sort of thing.
Another interesting link that I may have gotten from here:
https://rodwargaming.wordpress.com/miltary-historical-research/military-historical-research/basic-formations-and-movement-drills/
Pendraken, like any figures are too wide.
The absolute closest I've been able to base, including clipping the bases, is 3 in 20mm, and 6 in 40, showing it's consistent.
30/3 = 6.7mm figure.
5'7"=1700mm
1700÷11mm per fig =1:155 scale
6.7 × 155 =1m36 frontage per man. That's 3'4" to the old and out of touch.
Measure out 20mm ×155 on the floor. That's 3m10, about 10 feet. Stand with two mates, and look at how much space you have.
