An end to tiny helicopter blues.
Started by fsn, 22 July 2019, 08:17:46 PM
Gentlemen.
I may have found the answer to my tiny helicopter (and 10mm prop plane) problem. I found on Amazon some clear round stickers (100 for £1.40). I stick two together, pierce a hole in the middle and voila! Rotors.
https://www.amazon.co.uk/gp/product/B003JM2CES/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Took some piccies on my phone, but they're ... not good.
Dr Dave
Sounds good, but I can see the gum twixt the two layers picking up fluff etc... plus, they look "floppy", not rigid.
My solution to the props on aircraft is to completely remove them. But I can see that might look good on a helicopter.
Quote from: Dr Dave on 22 July 2019, 08:54:08 PM
Sounds good, but I can see the gum twixt the two layers picking up fluff etc... plus, they look “floppy”, not rigid.
Putting two together they're not rigid, but flexible. They seem to hold their shape well.
Aye, but I yearn for some indication of whirring airscrews.
There must be some form of clear plastic/acetate (of a suitable thickness) sheeting that can be cut to the right size with compass cutters......
Isn't there ?
I'll bet there's something suitable, made by whoever makes  the plasticard sheets
If you can find something 'cuttable', Nobby.... you can have my compass cutters.....They're just sitting in a drawer doing bog all.
I can't remember if I've ever even used them. :o
The punch looks it does the job to perfection.  :)
 :-bd =D> :-bd
Someone is about to have a bad day ;)
Yeah, the fitter and maintenance teams...  ;)
