French WW2 Engineers in 20mm
Started by Orcs, 10 July 2019, 07:36:11 AM
10 July 2019, 07:36:11 AM Last Edit: 10 July 2019, 07:47:53 AM by Orcs
Hi All,
Just started a WW2 French 20mm  Chain of Command Platoon. O am looking for suitable engineer figures, that I can convert either with a head swap or a "paint conversion". For head swaps ideally they nee to be metal figures, not the polythene ones.
Does the hive mind of the Forum know of any?
I had good answers. Then saw the scale...
THanks for that,  I am after combat type engineers, mine clearing, Wire cutting and possibly a flame thrower.
Hello Orcs
Well The only ones I could find are some FAA figures, which includes a flame thrower https://www.faaminiatures.com/p-275-frn-11-engineers.aspx
They don't cover the full range of stuff you're looking for, but maybe a start.
This article (where I got the info on these engineers) also covers scratchbuilding some engineers https://baberonwargames.blogspot.com/2018/11/french-additions-for-tunisia.html
GrumpoyOldMan
If these are 1940 types there would be no minesweepers, they weren't around till 41 at the earliest. Prior to that it was probing with bayonets (or smoke grenade can keys in my case). Think you will need to convert prone figures for both mine clearing and wire cutting. The old Airfix WWI set may be a help.
Aksu
The lack of mine clearing is something that shocked me when I was reading about the Saar offensive 1939. Tanks rolling onward until immobilised in a minefield. I suppose if you have a purely defensive doctrine you won't need expensive specialist kit that is only useful in an attack.
Aksu
Quote from: ianrs54 on 12 July 2019, 07:23:58 AM
I have found a geed Britsh mineclearer  at SHQ, probing  with a slick and levering a mine out of the ground. I will do a head swap
Quote from: GrumpyOldMan on 11 July 2019, 11:05:04 PM
Hello Orcs
GrumpoyOldMan
Hadn't realised hat they were still in production!.
The article looks interesting
