Blank dice now available!
Started by Leon, 07 July 2019, 11:30:43 PM
07 July 2019, 11:30:43 PM Last Edit: 07 July 2019, 11:33:24 PM by Leon
We get asked about these quite regularly so we've added some blank dice to the Minibits site.  These are 14mm diameter so a touch bigger than the regular dice we sell, and are priced at £1.50 per bag of 10 dice.
Blank Dice - http://www.minibits.net/dice/blank-dice/
Available in:
- Black
- Blue
- Green
- Orange
- Purple
- Red
- White
- Yellow
So you can now throw the dice and choose what number should be on top  :)
Quote from: Orcs on 08 July 2019, 04:14:21 PM
Yep, or just put an extra '6' on it if you like...
What to use these for, I'm drawing a blank...
Oi, let me get my arm out before you start chewing!
Perfect - I can finally have a die marked for my ruleset - 1, 2, C, Green, Pig, Techno
Dave Fielder
That's six memes on each cube ...
Quote from: fsn on 08 July 2019, 08:27:38 PM
If Techno comes up on the dice.....Is that good or bad, Nobby ?
Depends, Techno. It usually means "minor injuries", but if you throw a double Techno then you are gifted with new (and beautifully sculpted) reinforcements.    :)
 ;D ;D ;D ;D
I thought it might have something to do with injuries !
But my dice either have all 1's or all 6's, and alternate depending on what is the worse, so if I need highe they be 1's, low they be 6's. Blank is therefore no good.
You do that anyway.
