26 May 2020, 04:29:25 AM
299185 Posts in 17602 Topics by 2238 Members
Latest Member: Ave75
| |-+  Painting & Modelling
| | | |-+  Basing Sand for 10mm
Pages: [1] 2 Go Down Print
Author Topic: Basing Sand for 10mm  (Read 2240 times)
Noktu
« on: 01 July 2019, 05:34:08 AM »
Hey guys, what basing sand you tend to use for your miniatures?
I'm looking for ready made bags of fine grain sand for 10mm. As I feel like the stuff I'm using right now is a tad bit on the large side.
Pictures would be great!
mad lemmey
Marquis
« Reply #1 on: 01 July 2019, 07:09:50 AM »
I use a mix of red builders sand and silver (play) sand.
Off to the Shed of Decency.
Count
« Reply #2 on: 01 July 2019, 07:35:19 AM »
Budgie sand, from a pet shop ?.....I seem to remember that was a pretty fine consistency.....Though you might need to pick out some of the tiny pieces of shell that's mixed in.
« Reply #3 on: 01 July 2019, 07:35:26 AM »
I am fierecely loyal to Pendraken. If they can't supply my 10mm needs, then it's not worth doing until they can supply my needs.
Hence I use Minibits sand BAS-MS1, as fine as a fine thing on a fine day up in court facing a fine. It is said, by those whose are under some sort of watch list, that each grain is inspected by Milady herself, partially because she hasn't been mentioned in a while, and each tub is gently kissed by her unnaturally perfect lips in blessing before being sent out.
There is a camp (well more of a hospital really) that say it is best Middle-borough sand, robbed by specialist ninja-dwarves (Techno get cracking on those) from only the finest building contractors. Others, with a more twisted state of mind say that it is medical sand specially designed for getting into swimwear and causing the most lamentable itching.
The truth though is that it's a very fine sand, and goes onto bases beautifully.
Get some today, remember BAS-MS1, the wittily entitled "Fine Sand, 250g" (you know, Dave paid an ad agency 2000 for that title  Roll eyes )  at only 2.30 for 250g. Get yours today and if you quote code FSN1 on your order, nothing much will happen - for free!
Sorry chaps. It's the heat.
Lord Oik of Runcorn
Oik of the Year 2013
Oik of the Year 2014
ianrs54
« Reply #4 on: 01 July 2019, 08:26:13 AM »
I bought 30 kg of sandbox sand from Argos over 10 years ago, then took it home on the bus. Still using it.
« Reply #5 on: 01 July 2019, 08:29:20 AM »
Builders sand for me.
2017 Paint-Off - 2 x Winner!
Noktu
« Reply #6 on: 01 July 2019, 09:28:40 AM »
I added a bag of the fine sand FSN mentioned on my order. I prefer modelling sand as it has been cleaned prior to bagging. Normal builder sand includes too much dust to my liking.
However, sand that's available all around us, is what I use when doing terrain.
Major General
« Reply #7 on: 01 July 2019, 10:59:56 AM »
I've a bag of builders sand from, err, Homebase? B&Q? Somewhere that's now gone bust, through the receivers and broken up for parts? It's been a while... like Ian, it was about 30kg's and has done me nearly a decade Cheesy
Probably a bit big for 6mm, maybe 10mm, but tbh it's close enough and it works and it was about 2.50 as well Wink
I have been known to nab a bit out the spare sand for the wee ones sandbox on occasion though.
Ace of Spades
« Reply #8 on: 01 July 2019, 11:15:04 AM »
I use the white sand for bird cages. Have to get the bits of shell out but I find it excellent for 10mm.
Rob
Shedman
« Reply #9 on: 01 July 2019, 11:36:12 AM »
I use playpit sand from B&Q mixed with  Javis Ballast Chippings
« Reply #10 on: 01 July 2019, 01:11:45 PM »
I nicked a load of sand from s fire bucket about 20 years agp and still using it. The fire bucket was never needed and the building has since been demolished.
Major General
« Reply #11 on: 01 July 2019, 01:19:05 PM »
Were the two things related, Leman Cheesy
Glorfindel
Captain
« Reply #12 on: 01 July 2019, 01:39:57 PM »
Any fine play sand should do the trick.   Buy one bag - enough for a lifetime.
Phil
« Reply #13 on: 01 July 2019, 02:18:58 PM »
Main thing is make sure it's dry.
« Reply #14 on: 02 July 2019, 05:41:17 AM »
With  sand it's probably worth cooking it for a couple of hours to make sure any fungus and bacteria are killed off
I use extra fine  gravel I found on eBay
Pages: [1] 2 Go Up Print
