29 February 2020, 03:28:44 AM
The 1809 Napoleonic expansion has been released!
291892 Posts in 17348 Topics by 2203 Members
Latest Member: NogegoN
| |-+  Resources
| | |-+  Resources - 20th Century
| | | |-+  Can you spot the V1 launcher.
Poll
Question: Where is the V1 launcher?  (Voting closed: 02 July 2019, 07:20:42 PM)
Top - 7 (25%)
Middle - 5 (17.9%)
Bottom - 6 (21.4%)
Left - 1 (3.6%)
Right - 9 (32.1%)
Total Voters: 21
Pages: [1] 2 Go Down Print
Author Topic: Can you spot the V1 launcher.  (Read 1749 times)
mad lemmey
Marquis
« on: 25 June 2019, 07:20:42 PM »
As dis ;)cussed in the V1 release thread, a challange.
Can you spot the V1 launcher?
You can add a poll option, or just guess and reply.
Photo courtesy of Medmanham Collection at the Military Intelligence Museum  Cool
I will post further V1 photos later in teh week, because one gives it away!
« Reply #1 on: 25 June 2019, 10:00:51 PM »
I guessed top, but without a good magnifying lens, a bit of a guess to be honest.
2017 Paint-Off - 2 x Winner!
« Reply #2 on: 25 June 2019, 10:26:50 PM »
I'm thinking bottom, in the middle right around what looks like an enclosure. Seems to be a lot of tracks and activity going on there.
I know very little about this period though so could be missing the obvious!
Viscount
« Reply #3 on: 26 June 2019, 12:36:41 AM »
I've gone middle right, just to the top-right of those two bomb craters.  Seems to be something 'rampy' pointing to the north-east in that field.  Although right in it's line of trajectory seems to be some houses, so I'm not overly confident!
« Reply #4 on: 26 June 2019, 01:28:35 AM »
If you want a PI, hire one. We're not here to crowd source military intelligence. Make sure you don't plan a raid until you do.
Kiwidave
Cats are mercenaries. Dogs are loyal.
« Reply #5 on: 26 June 2019, 02:07:45 AM »
I concur Smiley
Count
« Reply #6 on: 26 June 2019, 08:07:41 AM »
I tried enlarging the photo, and I still couldn't see anything that I'd confidently identify as the ramp.
Something in the top left corner is a possibility.....But I wouldn't lay any money on that.
Even tried searching for the image, hoping there would be a circle around 'the target'. Embarrassed
Cavillarius
« Reply #7 on: 26 June 2019, 08:19:55 AM »
V1 or 2? I think I see a 2..
« Last Edit: 26 June 2019, 08:30:54 AM by Cavillarius » Logged
ianrs54
« Reply #8 on: 26 June 2019, 08:51:04 AM »
I reckoned on bottom right as well.
« Reply #9 on: 26 June 2019, 11:17:56 AM »
Well, I'm sure it's just as well I wasn't tasked with deciphering photo recon images in WW2! Smiley
I'll go for whatever the object facing NW (if the top of the photo is N) just W of the cluster of buildings in the upper left of the image.
Count
« Reply #10 on: 26 June 2019, 12:05:47 PM »
That's probably the same 'wossname' I was looking at, Mike.
Last time I bet a 'shiny new sixpence' (about 10 years ago) was when I challenged someone to get inside my shot on a golf course from about 100 yards. (90 ? meters)
I ended up roughly 2 feet from the pin.
The rotten sod got to within a few inches (centimeters) from the hole.
Took me AGES to find an old sixpence so I could 'pay the debt'.
Major General
« Reply #11 on: 26 June 2019, 04:47:35 PM »
I’d go with Leon and KiwiDave with about a .10 confidence level. The shadow of the “ramp” object doesn’t suggest a higher elevation at one end.
http://inredcoatragsattired.com
Disputatio stellas lucra
mad lemmey
Marquis
« Reply #12 on: 05 July 2019, 12:15:43 AM »
Sorry to keep you all waiting, but the answer none of you have been waiting for...
 Grin
This was the first identified clue as to where launchers were. There is tell-tail sign is the long streak across the field, bottom mid left to bottom mid right in this example, which is the mark the V1 launch trolley leaves when it hits the ground after launch. Once you know to look for this, the launch site becomes easier, or in this case, a bombing target!
So, back to our original image, is that streak visible?
Yes, it is middle right, heading downwards. A further clue is the nice, efficent germans after each launch take a truck out to pick up the trolley, and turn around in the same spot each time, leaving a telltale loop.
Trace both of those lines backwards, you can spot the ramp! There is even damage to the roof of the building on the way as a few trollies fell short, and a lump taken out of a pipeline to get the V1 to safely launch. The ramp is in the middle of the factory complex!
A few other telltale shots
V1 on launcher, this allowed the allies to look for the control hut.
A Tempest in pursuit to tip the V1 wings
And this last shot was one of The Intelligence Corps real triumphs
Once we realised that V1s flew straight and level, until they plunged, you could track their routes back to occupied territory to work out where the launchers were, then you could look at the recon shots to spot the actual site and level it!
Also, we had several German agents we had 'turned' who were feeding false information about the V1 hits back to Germany, and were telling their handlers that the V1s were all overshooting London by about 20 mile, so the Germans cut the fuel, meaning that the rockets were in fact dropping 20miles short!  Grin Not great for Kent, but it save a lot of hits on London.
Smiley
« Reply #13 on: 05 July 2019, 01:51:39 AM »
Fascinating Nerd
I was miles off
Thanks for sharing ML
« Reply #14 on: 05 July 2019, 06:46:16 AM »
Very interesting.
Pages: [1] 2 Go Up Print
