Redoubt built using rubberised planking
Started by Norm, 31 May 2019, 03:38:15 PM
From the bits I bought earlier in the week from the rail model shop ... the first redoubt is built.
Link
http://battlefieldswarriors.blogspot.com/2019/05/redoubt-no-1.html
lowlylowlycook
Interesting project, Norm. I'm thinking to make gun platforms for Flodden period artillery. You provided a blueprint!
Sleep with clean hands ...
jambo1
Impressive work, Norm !!  :-bd
Slightly disappointed. Thought that the rubberised planking was a C19 technology for making cannon balls bounce off the redoubt.  :-[
Once I got over that, I'm impressed with the result.  :D
Nobby.......You're an oik !! ;)
That's a nicely done project, and a very good write up to show us all how easy it would be to make one ourselves.
Did you use the Ronseal wood filler straight onto the plastic card? I've just based up some houses on some big bits of plastic card, and I am wondering what to use to stick some texture on them?
Quote from: fsn on 01 June 2019, 07:59:03 AM
;D  Me, too! Turns out the product is "Retaining Wall" in strips of flexible vinyl moulded with a wood planking effect. I wonder if the small size would be suitable for 10mm? Here's a direct link to the product page, itself. http://www.choochenterprises.com/Nwalls.html  I've used matchsticks in the past to obtain this kind of wooden retaining wall effect but nowhere near as neat. Very effective and, together with all of the other materials used, a great end result, Norm.  :-bd
I think the small size would be ok for 10mm. Looking at the picture when you click through and it shows you and actual sized 1" sample, it looks reasonable size for 10mm.
I have some plastic sheets of bricks, stones and wood that are N scale model railway sized, and these are very fine in their detail, often a bit smaller than what is seen on wargames stuff (which varies hugely)
It looks very good to me, is it available in the UK I wonder?
I'm not as daft as I thought. Just watching a video on USS Galena (Ironclad ACW) which had a rubber layer!
:D
