Welcome,
Guest
. Please
login
or
register
24 January 2021, 06:55:37 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
We've released an excellent
MDF Siege Tower and Trebuchet
to our Medieval range!
314982
Posts in
18227
Topics by
2283
Members
Latest Member:
dariusr
Pendraken Rules!
Blitzkrieg Commander IV
BKC-IV Rule Queries
"Rear line" and "Fast" issues
« previous
next »
Pages:
1
2
Author
Topic: "Rear line" and "Fast" issues (Read 1881 times)
Dr Dave
Guest
Re: "Rear line" and "Fast" issues
Reply #15 on:
03 May 2019, 03:21:00 PM »
Mark,
Now I am confused
Quote from: Big Insect on 03 May 2019, 01:58:05 PM
Fast units do not actually have to move or have moved to utilize the Fast ability
But if it doesn't even have to move -
it could be stationary and get the fast benefit
If there’s no threshold as to how fast the vehicle must move in order to benefit from it. Personally I think it is a
good rule
that is
unworkable
. Imagine a vehicle with a fast 25 cm move. Say it has been qualified that it needs to move 25 cm to benefit from being fast. But it only moved 20 cm, all the owner has to say is that it did move 25, but in a wavey-line-drive up to the spot 20 from its start point. :-
If first point is right - uhhhhhh OK. I probably wont be able to swing that one past me fellow players in a game.
If the second point is right - uhhhh, OK. But I can't see people liking that either.
The odd thing is I've always thought that bkc lacked some rule on target speed - but this seems to be unworkable.
Reply #16 on:
03 May 2019, 03:49:19 PM »
With all this it needs to be remembered that a unit is not a single tank/vehicle - it's a formation consisting of a number of vehicles and their support, conducting various actions in a move.
It could also be argued that a particular formation might have a more dispersed doctrine than another, this might vary from country to country or even between different unit organisation in the same army. Should that be depicted? I'd argue it is going down to a granularity that applies more to a skirmish level game - in which case Bolt Action or Crossfire might be a better set of rules to play.
In fact, the Mongolian scout cavalry in the Early Russian list probably could be classified as 'dispersed' but it was equally fast moving and also relatively low profile.
The principle of 'Fast' as a characteristic was introduced to cover off the very issue you've raised, that a unit moving quickly is a more difficult target. I did consider giving the -1 d6 effect on Fast for area fire templates as well. As it could potentially be argued that a Fast vehicle moves more quickly through the zone of fire than a slower one. But does that expose it to more shells or aircraft cannon rounds or less than if it remained stationary or moved more slowly ... I don't know but it all seemed too much detail.
There is also a Commander series rules principle, that you try minimize 'book keeping' as much as possible. So recording if a unit had or hadn't moved to gain the Fast benefit was a step too far IMHO. There is the overall question as to whether a unit that moved in the Active players turn is considered to be moving in the following turn (the opponents active turn)?
I suppose you could use small brown stained cotton wool 'dust cloud' markers to indicate that a unit has moved - but as you say - has it moved far enough to qualify as Fast or not.
TBF - if you find the concept so difficult, by all means in your own games do just drop the Fast Special Characteristic.
Reply #17 on:
03 May 2019, 04:01:33 PM »
Thinking about it - 'Fast' is a bit like 'Hover' or 'Grav' capabilities for units in FWC.
Units are considered to have the benefits or disadvantages of this type of movement/characteristic even if they are stationary or even in defenses.
It's just a game mechanism
Dr Dave
Guest
Reply #18 on:
03 May 2019, 04:50:09 PM »
Were doing a 1940 BEF game tomorrow.
The Vickers A13 is fast. Fast represents them generally "milling about"
A13s on a hill and get the +1 for the cover - which represents them being hull down? +1 for fast as well means they are hit on a 6.
Surely they can't benefit from both - they cant be in cover and driving around a lot. It's a tank.
I can see the benefit of the fast rule in the open - hence the British cruiser "charges".
But surely only one of those modifiers can apply at a time?
Sorry to pester, but I'm going to have to "sell" this to a bunch f hairy arsed ne'er-do-wells tomorrow
Last Edit: 03 May 2019, 06:51:44 PM by Dr Dave
Sandinista
Reply #19 on:
04 May 2019, 06:41:47 AM »
Quote from: Dr Dave on 23 April 2019, 11:04:40 AM
Though I'm not sure how you can lie a motor cycle combination down.
Try riding one without a passenger in the wind
Ian
http://kerikerigamer.blogspot.co.nz/
ianrs54
Reply #20 on:
04 May 2019, 08:16:44 AM »
But on it's side a combo would be bigger than on its wheels.
Reply #21 on:
04 May 2019, 04:54:15 PM »
What can I say Dr Dave!
If you want the 'Fast' special characteristic to only apply if a unit with it has moved (any distance at all) then that's fine by me. That's your prerogative
I hope the game goes well ... a game report is always well received and much appreciated.
Dr Dave
Guest
Reply #22 on:
05 May 2019, 08:43:44 AM »
Ok.
Yes it’s was a great game thanks. The guys were unclear on how to resolve the A13 question so we did 1st Army tank brigades effort at Arras. The Brits (me) got a tonking. I had some dire command rolls and just as the Matilda’s got into range the blunders came thick and fast. Eventually the CV was permanently reduced from 8 to 6, so a bit crippling under the barrels of 3x 88s and 2x 105s.
It was tremendous fun and very very atmospheric. My Pal has everything beautifully painted up in 15 mm, and showed us his Pz regt for Poland 39 - grey and brown camo with white crosses. He has 2 in just grey with black/white crosses for 1940 as well. A proper megalomaniac. He has a house just south of the original battlefield nr Arras so is very familiar with the area.
We’ll hold off on the A13 actions until we’ve given more thought as a group and folks have decided if they are fast or if it’s a typo.
Cross698
Reply #23 on:
05 May 2019, 09:47:42 AM »
I thought the A13 was the first based on the Christie Suspension and thought it was a fast tank at 30mph and was the basis for the Coventer/Crusader. The A10 was also designated as a "cruiser" tank, but originally designed as a Close Support tank and was very slow. I did Arras as a weekend game a few years back, it was a fun game.
Dr Dave
Guest
Reply #24 on:
05 May 2019, 11:27:53 AM »
Yes, but it’s fast in the BEF list but not in North Africa, so we assumed one of them is a typo. Fast isn’t solely based on speed. Just awaiting a clarification but Mark has buried his books on British cruiser tanks in his garden.
Reply #25 on:
05 May 2019, 10:56:11 PM »
The A13 Mk.1 had speed 48kmh on road, 38kmh cross-country.
The A-13 Mk.II had speed 48kmh on road, 22kmh cross-country.
For a christie type suspension this is actually quite slow road speed, when you compare it to say BT-5 or BT-7, with only the 38kmh cross-country of the Mk.1 particularly fast.
To count as a "fast" characteristic whilst the model is halted hull down is a bit peculier, but could represent the tanks firing a few rapid shots, reversing then reappearing quickly somewhere else on the ridge. Appropriate for a Hellcat, not something I've heard of for British tank tactics.
Dr Dave
Guest
Reply #26 on:
08 May 2019, 05:40:14 PM »
I’m not sure bkc was granular enough in design to differentiate twixt mk1 and mk2? Besides, both types are in France surely?
Pages:
1
2
« previous
next »
Please select a destination:
Welcome
=> Forum Info
=> Intro's and Welcomes
=> Requests
Wider Wargaming
===> 20th Century
Pendraken News & Info!
=> Shows
=> Photos
Wider Wargaming
===> Fantasy & Sci-Fi
=> Rules
Non-Wargaming Discussion
=> Chat & News
Wider Wargaming
=> General Discussion
=> General Pendraken
=> Fun Stuff
Wider Wargaming
=> Painting & Modelling
===> Painting Diaries
=> Batreps
===> Clubs/Societies
===> Sport
Wider Wargaming
===> Dungeons
=> Books
===> Scenics
=> New Figure Previews
=====> 2010 Show Stuff
Archive
===> PPC 2011!
===> WW2 Requests
===> WW1-SCW Requests
===> Fantasy/Sci-Fi Requests
===> Fantasy/Sci-Fi Photos
===> WW2 Photos
===> WW1/SCW Photos
Archive
=> Competitions
Welcome
===> In the Line of Fire!
Minibits Topics
=> General Minibits
Wider Wargaming
=> Resources
=====> 2011 Show Stuff
=======> 2010 & 2011 Previews
Archive
===> PPC 2012!
===> 18th Century Requests
Wider Wargaming
===> Blogs
Archive
Wider Wargaming
===> Downloadable Rules
===> Resources - 20th Century
Archive
=> The Big Move
=====> 2012 Show Stuff
Archive
===> PPC 2013!
=======> 2012 Previews
Wider Wargaming
=> Non-Pendraken Stuff
=====> 2013 Show Stuff
=======> 2013 Previews
Archive
===> PPC 2014!
===> Smoggy '13!
Pendraken Rules!
=> Warband
=======> 2014 Previews
=====> 2014 Show Stuff
Archive
===> PPC 2015!
===> Post-War/Modern Requests
Wider Wargaming
=> Genre/Period Discussion
=> Networking
Pendraken Rules!
=> Cold War Commander
===> BKC-III
=> Future War Commander
=> New Releases
=======> 2014 Releases
=======> 2013 Releases
=======> 2012 Releases
=======> 2010 & 2011 Releases
Archive
=> Battleground
===> Battleground 2015!
===> Old Newsletters
=====> 2015 Show Stuff
=======> 2015 Releases
===> Previous Years
===> Previous Years' Releases
===> Previous Years' Previews
=======> 2015 Previews
Archive
===> PPC 2016!
===> Battleground 2016
===> Pendraken Website Photos
=====> 2016 Show Stuff
=====> 2016 Releases
=====> 2016 Previews
Pendraken Rules!
=====> BKC-III Rule Queries
=====> BKC-III Miniatures
=====> BKC-III Battles
Archive
===> Battleground 2017!
===> PPO 2017!
=====> 2017 Releases
=====> 2017 Previews
=====> 2017 Show Stuff
===> Post-War/Modern Photos
Archive
===> PPC 2018!
===> Battleground 2018!
=====> 2018 Show Stuff
=====> 2018 Releases
=====> 2018 Previews
=====> Older Releases
=====> Older Previews
Pendraken Rules!
=> Blitzkrieg Commander IV
===> BKC-IV Rule Queries
===> BKC-IV Miniatures
===> BKC-IV Battles
===> BKC-IV - Army Lists!
Archive
===> Battleground 2019!
=====> 2019 Show Stuff
=====> 2019 Releases
=====> 2019 Previews
Wider Wargaming
===> Proxy Figures/Models
===> Scams & Spams
=====> 2020 Show Stuff
=====> 2020 Releases
=====> 2020 Previews
=> Painting Competition 2021!
Loading...
