26 June 2019, 02:57:21 PM
Blitzkrieg Commander IV is now available here!
279052 Posts in 16672 Topics by 2187 Members
Latest Member: steveww57
|-+  Pendraken Rules!
| | |-+  Additions, Omissions, Errata etc - please post here
Pages: 1 ... 3 4 [5] 6 7 Go Down Print
Author Topic: Additions, Omissions, Errata etc - please post here  (Read 2599 times)
Dr Dave
« Reply #60 on: 01 May 2019, 08:28:09 AM »
Recce
[edit] Posted on 01 May 2019 at 07:54:50 GMT
This rule is inherent across the rules sets and has been copy pasted  to bkc4.
It states the score required to communicate will be 1 per full 10cm ie 1 upto 10cm, 2 up to 20 etc. Further on it states 1 is always a fail.
This doesn't make sence as you need a minimum or 2 for any distance up to 20cm.
Can anyone shed light on this. In the original concept from bkc1 days, if memory serves anything up to 10 cm was automatic.
Errata/ faq required.
IIRC, even in in BKC1, a roll of 1 on a d6 was always a fail.
“In war possession of ground is nine tenths of the law,
And the infantry are the bailiff’s men”
« Reply #61 on: 01 May 2019, 08:29:16 AM »
BKCII had quite a few changes from BKCI, but it's so long since I played the latter, so your example may have been superceded in BKCII. Hope this makes sense?
2017 Paint-Off - 2 x Winner!
Cross698
« Reply #62 on: 01 May 2019, 10:00:33 AM »
Recce
BKCv2 a  - can RECCE up to 60 cm and a 1 was always a fail.
This is the same for Reconnoitre, but Communication is totally different in v4, still D6 but now has modifiers ;-
50 -60 cm add +2, 30 - 50 +1, 20 - 30 0, 0 - 20 -1, Higher ground -1, target is INF or Support Unit or Low profile -1
Spotted on Target in open 4+, Soft/Partial 5+ Hard cover 6 - and 1 is still a fail. Targets requiring a score of 7 or more cannot be spotted and this is for CV bonus.
Moderator
Captain
« Reply #63 on: 01 May 2019, 11:49:08 AM »
In the Recce rules - a score of 1 to spot for communication (regardless of the distance involved) is always a fail.
There must be a possibility that the Recce might fail to communicate (radio failure, paper info lost on a desk, carrier pigeon eaten by hungry falcon etc.)
The additional factors come out of the Recce House Rules from CWC.
Many thanks
vladvondrak
« Reply #64 on: 02 May 2019, 06:38:00 AM »
You are still missing the point . It contradicts itself, it say you need a 1 at 10cm to succeed, then states 1s are always fails. The whole thing is ambiguous.
Cross698
« Reply #65 on: 02 May 2019, 08:25:23 AM »
I understand what you mean, but 1 is always a fail, but it should be shown as
10 to 20 cm 2
20 to 30 cm 3
etc
But I just think that in RECCE as in Engineering a "1" is always a fail.
Dr Dave
« Reply #66 on: 02 May 2019, 08:58:39 AM »
10 to 20 cm 2
20 to 30 cm 3
etc
No, shouldn't it be 0 - 20 cm 2 ? Tongue
Cross698
« Reply #67 on: 02 May 2019, 11:12:35 AM »
yes
ianrs54
« Reply #68 on: 02 May 2019, 12:05:53 PM »
Nother niggle - the Grants in the British FE list are really Lee's - the British Army designated Lees as Grant MkIV.
Major General
« Reply #69 on: 02 May 2019, 12:30:26 PM »
The only time it matters is if there are modifiers, as a base of 1 with a -1 to the success (ie now needing a 2), still only fails on a roll of 1
Whereas if it is a base of 2 with a -1 modifier  you now fail on a 1 or 2
Dr Dave
« Reply #70 on: 02 May 2019, 06:37:33 PM »
Crystal!
I’ll be sticking to bkc2 recce - simpler, quicker and faster.  Tongue
We’ve always played the comms were to any command unit in the formation anyway.
Major General
« Reply #71 on: 02 May 2019, 10:28:17 PM »
Pill boxes and Trenches - points
Looking at these two Field Defences, I'm a bit confused by the points difference between the two.
Trenches are 5pts, give a 5+ save, protect 1 infantry unit
Pill boxes, are 25pts, give a 5+ save, protect 1 infantry unit, have a 90º firing arc, and can only be attacked in this arc
It seems Trenches are much better value?
I do think this may well be a carry over from much earlier versions.
Solo General
« Reply #72 on: 02 May 2019, 10:36:44 PM »
Active vs. Inactive Player Question
BKC IV - Page 18 - Sequence of Play - Opening paragraph, 2nd sentence, states: "....current player being referred to as the Active Player and the opponent being the Inactive Player."
BKC IV - Page 18 - Sequence of Play - End Phase, 1st line: "Remove outstanding hits from all of the active player's units on the table."
BKC IV - Page 39 - Firing Example - 3rd paragraph from bottom, beginning with: "At the end of the turn, all outstanding hits are removed from play, so the two hits against the PZ-II are removed. It is still suppressed..."  In this case, the PZ II, hits are being removed from the Inactive Player's unit during the active player's End Phase.
The Firing Example was taken from BKC II and just about matches what is in BKC IV.
BKC II, Page 9 - Sequence of Play - End Phase, 1st line: "Remove outstanding hits from all units on the table."  It appears the wording was added in BKC IV with the words "of the active player."  Repeated on Page 36 BKC II "...remove outstanding hits..." and...Suppression markers from all units on the table..."
BKC IV - Page 56 - End Phase - 1st Paragraph, 2nd Sentence:  "Once the end phase is complete, your turn has ended and your opponent's turn will begin..."
Question: Do we leave both the hits and suppression markers on the Inactive Player's unit when the Active Player's End Phase ends as BKC IV directs?
One of our members spotted this and requested clarification. Thanks in advance for your answer.
T-Square
« Reply #73 on: 03 May 2019, 03:26:17 AM »
Yes, just remove hits and suppression markers from the active player’s units only.
flamingpig0
« Reply #74 on: 03 May 2019, 11:53:15 AM »
Shouldn't there be an option for the Panzer iii oi have schurzen from 1943 ?
Pages: 1 ... 3 4 [5] 6 7 Go Up Print
