Is varnishing worthwhile?
Started by mmcv, 12 January 2019, 06:21:56 PM
I am a previous convert to Winsor & Newton acrylic varnishes.
I use the brush on matt version for most things where it is important to get good coverage to minimise handling wear and tear.
I use the brush on gloss version for the same reasons on my 'old school' collections. It dries quickly and appears to be fairly tough and shiny.
More recently I continue to use the matt version but then top coat with a de luxe spray matt varnish from Minibits. It looks just that bit more matt. I use this combination on commission work.
All of the above.
I spay varnish everything - after basing. Most things are varnished matt, but I have used silk and gloss on tiny aeroplanes and tinier ships.
For some, very selective figures, I will use W&N varnish selectively. For example my Greek Gods are matt for the most part, but the armours are brushed gloss.
I find the easist thing is to make sure I pick things up by the base whenever possible.
I used to use Letracoat, Matt Varnish....Never ever had a duff tin of that !!
Sadly, I'm not sure if that's even available anymore.  :(
Used to buy it from larger stationery shops.
To make ABSOLUTELY sure I didn't have a rogue tin, I used to spray the paper that the figures were destined to stand on, when they were varnished..... dry the varnish with a hairdryer (Don't tell the better half you're doing this)...and check it was 'as I wanted'.
Like I say...never had a problem with it.
I reckon I was the better half!
