Hearts of Oak (well MDF...)
Lockdown helped, and being Austrians.
Did you know the inside of the box of Aldi own brand Wheat (not Weeta) biscuits (not bix) is the same colour as MDF?
How do I know?  I've made 'lids' for the movement trays - I can leave the marker tiles in the trays, stack them up and rubber band the lid on the top, meaning I don't have to spend time at the start of a game putting them in.  I might make card 'unit templates' to put in so when unpacked its easy to see what figures go where - especially for the Austrians who have a wide array of units and uniforms.
Gentlemen of the Officer's Mess,
and Nobby,
Advice please.
Thinking of getting a French Ally - which one do you suggest. Nice flags are an advantage. One that I could use as just a Division within a corps would be nice.
and secondly
Painting Brunswickers. Would you go black, or could/should I use the very dark grey - Citadel 'Standard'?
Brunswickers - if they're 3D figures I'm sold on Citadels black Contrast paint - works really well!
If it's the MDF... I'd go dark grey-black, give a little bit of light to catch the eye?
Definitely dark grey-black, I hardly ever use black now, certainly not for significant areas
Brunswickers - in theory quick to paint. You could ask Walt to go over the uiniform are lightly with the laser - then they would only need a dry brush of grey.
BUT he might charge you extra as "pre painted " pre- burnt?
I'm thinking Hesse-Darmstatd. I like the flag (similar to Prussian and Russian).  5 Battalions, so just 1 unit in FoG.
Also thinking might do base edges green, but not movement trays.
A good project is a French army with no frenchmen in it other than the Marshals..
03 May 2020, 10:18:14 AM #254 Last Edit: 03 May 2020, 12:13:26 PM by Last Hussar
VII Corps is 8 Small units of Bavarian infantry with 1 large and 1 small unit of cavalry
VIII Corps for Wurttemberg is 5 small infantry and 3 small cavalry
Each are in 2 Divisions
That is basically a perfectly good FoGN army - 18 units in 4 commands, and one that can be played by two people.  They would play exactly the same as French - the troops are as good in the army book, but more colourful. AND with 2 larger flags per unit, which differ between units
Tempting...    :-
I've got 16 French infantry units, need a couple more Light, and more Cavalry.  I'd also like the Imperial Guard- that's just 6 Infantry plus 4 Cavalry (and for FoG only 2 Cavalry).  A unit is only £2.  £60 gives me 3 'different' Corps.
Very tempting.  :d
