What are the rules you use ?
Started by Nicofig, 17 March 2010, 08:00:05 PM
Nicofig
Hi,
what are the rules you use with yours Pendraken figures ?
For me :
- Might and Reason for WSS, SYW and FPW
And I would like use Black Powder for FPW and Crimean as soon as we could find some Crimean french.  ;)
I want buy some fabntastic AWI range but I don't know what rules to use.
And you, yours rules ?
Thank you
Stefanpanzer
Bltzkrieg Commander WW2
Cold War Commander Moderns
Napoleon's Legacy - Napoleonics and ACW.
Tried Black Powder as well but it's not a very realistic game for me definately a put em up and knock em down set; fun I'm sure.
Bliztkrieg Commander
Future War Commander
Warmaster Ancients
Fire & Fury
Piquet
lentulus
Blitzkrieg Commander, and some home brews.
WHY do you use the rules you use?
Coracero
Warfare in the Age of Discovery (Thirty Years' War)
Command Decision: Test of Battle (World War II)
The 2 with some modifications here and there.
The Guardsman
Primary Flames of War (uuehh, don't shoot me!!! :-[), some homemade rules, and planning on buying Rapid Fire. :)
goat major
British Grenadier works well for AWI. Its quite complex though (based on GdB) so not to some peoples tastes. I'm using the 15mm basing and that looks about right with the 10mm figures (in fact i think that 15mm figures would look too squashed together on the sizes given). Or you could use the 25mm basing and have really big battalions. The main issue with that would be that BG counts the number of figures firing so you would need to adapt the ratio.
DanJ
Warmaster Ancients for Ancients but most of the Medieval lists and special rules are a bit "broken"
Home made rules for WW2 and WW1
Quote from: DanJ on 18 March 2010, 02:07:48 PM
Interesting.
In what way do you think they're broken?
Aart Brouwer
Some friends and I have used Spearhead a couple of times for our WWII Eastern Front games.
On the plus side we love the command system which is both 'realistic' and fun to work with. Commanders give written (or rather: drawn) orders to their subordinates before the start of the game. These have to be obeyed even if the tactical situation changes, unless commanders produce the required D6 throw to give them new orders.
On the downside the operational rules are a bit too rigid to our taste. Limited arcs of fire, static positions, some punishing modifiers for the Soviet players and too little diversity of speed and range for various vehicle classes.
Apparently Spearhead has the same tendency as FoW to result in more or less static clusters of hardware on the table slugging it out from behind hill tops and hedges and such. Tank formations usually advance like ships in line abreast because columns carry no positive movement modifiers unless on roads. Some thinking is clearly needed here - most probably on my part.
slinky
storming the reich for ww2
DBA for my ancients
Homebrew for my moderns
flying lead or nut's! for my skirmish games
Aart Brouwer
Quote from: slinky on 19 March 2010, 11:47:01 AM
I've never heard of Storming the Reich rules. Could you tell me a bit about them, please?
Aart
kustenjaeger
Greetings
Rules for my 10mm:
1.  Blitzkrieg Commander for WW2 Eastern Front (and Desert when built)
2.  If the Lord Saves Us for WWI Mesopotamia (platoon per stand - so roughly an Imperial brigade vs Turkish regiment plus supports)
3.  Poleaxed 2 for late mediaeval
4.  not yet sure for FPW
Of course a lot of the armies are still being painted ...
Regards
Edward
grimreaper
i use
Warmaster Ancients
Fire & Fury
and want to get  CWC next.
