17 September 2019, 05:16:46 AM
We've upgraded our Sd.Kfz 251 models!
283847 Posts in 16919 Topics by 2189 Members
Latest Member: MartinKnight1333
| | |-+  Magnetic sheet and steel paper recommendations?
Pages: 1 [2] Go Down Print
Author Topic: Magnetic sheet and steel paper recommendations?  (Read 1121 times)
Paper
« Reply #15 on: 02 April 2019, 10:52:12 PM »
For steel sheets I buy flashing from the hardware store.
I need to buy some nice magnetic sheets now that Iím mostly using metal bases.
« Reply #16 on: 02 April 2019, 11:13:57 PM »
To post a jpg file from your PC to a forum thread you need to use the Additional Options... tag below the text box.
You can add up to two pictures per post and they need to be 128k or less.
I use The GIMP to reduce the size but many other picture editing tools will let you edit size and/ or resolution.
Captain
« Reply #17 on: 16 April 2019, 12:33:24 PM »
Slight delay in updating.
These good folks: https://www.themetalstore.co.uk/products/mild-steel-sheet-uk-suppliers
Delivered me some 39cm^2 mild steel sheets (.8mm thick) at just over £2.50 a pop.
Their cutting service was excellent, quickly costed my requirements, and delivered the sheets without any hazardous burrs on the edges.
The sheets are fixed into the bottom of my pizza boxes using silicone sealant as adhesive.
Some of my little men (Those whose bases I've magnetised) are happily and safely resting in the boxes
Since each sheet add a klio to the load (and I'm stacking the boxes 6 deep), I've improvised supports by cutting some 40mm wooden blocks and applying a magnet to hold them in place.
I'm using 5 per box, one per corner and one in the centre (think of the "5" face on a D6.
For weatherproofing, I've found I can fit 2 x 16" Pizza boxes into a garden bag.
Steel + Magnets + Pizza boxes = Sorting, storage and transport solution.
I
Captain
« Reply #18 on: 17 April 2019, 01:04:08 PM »
With their delivery charges themetalstore tripled the cost of a £5 sheet to over £17.  I passed on that.
Pages: 1 [2] Go Up Print
