15 July 2020, 08:44:12 AM
303461 Posts in 17760 Topics by 2247 Members
Latest Member: Adamwest
| | |-+  Storage issues
Pages: 1 2 3 [4] 5 Go Down Print
Author Topic: Storage issues  (Read 5204 times)
« Reply #45 on: 30 December 2018, 01:44:49 PM »
A friend found a solution ... of sorts ... to the problem of magnetic base slippage.
His hills were not flocked but coated with iron filings and spray painted!
Units that spent too long defending a slope could become difficult to remove Smiley
Major General
Sir Oik of Westmarch
« Reply #46 on: 30 December 2018, 02:41:40 PM »
I found getting a good match of the magnets to the base more and more difficult as my eyesight required correction.
Another reason, through not a particularly good one, is that I found the magnetic stuff quite slippery, which changed almost any wargame hill into the Cresta Run.
Of course naked MDF is also very slippery, so that problem requires a different solution.
Don't fully understand the matching issue, Steve (I understand you are long sighted but, then again, you also collect/play with 10mm figs). You don't really need the magnet to match the base exactly. For example, most of my bases are 25mm x 25mm square and I cut 20mm x 20mm squares from the 0.55mm thick self adhesive magnetic sheets (which are 40mm wide x 200mm long) and stick them on the bottom of the base. This works equally well with my 10mm (up to 8 ) and 15mm (up to 4) figures on the 25mm square base.
Yes, there can be a problem on certain slopes with bases that have smooth undersides. Fortunately it doesn't happen too often in most games (unless you are doing a re-fight of The Battle of the Pyrenees). My solution was to cut a few bases or sabots from steel paper (I've only cut enough for one and a half units - about 4 sabots - that's how often I need them). I then stuck some thin self adhesive pads (you know, the type you get in the Pound Shop, etc. to stick to the underside of ornaments so that the base doesn't scratch your furniture) - on one side of the steel paper base. My magnetised bases stick to the steel paper base/sabot and the thin felt pad on the underside of the steel base/sabot grips the hill. Voila! No sliding.
(Unfortunately, I can't post photos on this forum but if you want some pics sent to you, drop me a personal message)
« Last Edit: 30 December 2018, 02:46:26 PM by Westmarcher » Logged
Noktu
« Reply #47 on: 05 January 2019, 12:54:31 PM »
Hey,
I wanted to share my storage solution here. I found some nice trays from the H&M store.
https://www2.hm.com/en_gb/productpage.0464712005.html
By adding floor protectors to the corners, I made them stackable and not moving on top of each other. I find them great for this scale.
1 by Atte Von Kraut, on Flickr
2 by Atte Von Kraut, on Flickr
3 by Atte Von Kraut, on Flickr
4 by Atte Von Kraut, on Flickr
« Reply #48 on: 05 January 2019, 02:47:56 PM »
They look good and sturdy!
I use these things https://www.amazon.co.uk/dp/B00TH5A37E/ref=cm_sw_r_cp_awdb_t1_ehmmCb7AECW5G which I find are a good height and size. Clear plastic is easy to see what's in it too without pulling it all out. Though I do like the dark wood trays for the presentation value.
« Reply #49 on: 05 January 2019, 03:32:04 PM »
I'm a Really Useful Box user. Lots of different sizes.
https://www.amazon.co.uk/Really-Useful-Box-Litre-Transparent/dp/B0771HDM11/ref=sr_1_6?s=officeproduct&ie=UTF8&qid=1546702234&sr=1-6&keywords=really+useful+10l
Lord Oik of Runcorn
Oik of the Year 2013
Oik of the Year 2014
« Reply #50 on: 05 January 2019, 04:44:27 PM »
I'm trying to standardize on 9L Really Useful Boxes for figures but have some bigger ones for boardgames that I have several add-ons for (I'm looking at you Firefly and Merchants and Marauders Smiley  )
https://www.ryman.co.uk/really-useful-storage-box-9-litre
« Reply #51 on: 05 January 2019, 06:36:04 PM »
I am also a 4L and 9L RUB man.
« Reply #52 on: 05 January 2019, 09:51:50 PM »
Hey,
Ooooh, I like those. Are they available in the physical store, or is it online only?
Cheers, M.
Noktu
« Reply #53 on: 06 January 2019, 12:00:33 AM »
Cheers, M.
Here in Finland H&M Stores mainly sell clothes, so I had to order them online. But their Mailing service is super fast, the order showed up in the nearby post just in 2 days.
« Reply #54 on: 07 January 2019, 10:32:15 PM »
All clearly stated stuff.
I'm on the lookout for a supplier of precision cut adhesive magnetic stuff - failing that I'll try cutting slightly undersize pieces.
Meanwhile I've found a grid of small blu-tack balls gives a good grip on the underlying surface.
It's main drawback is the time to detach an army from its boz.
« Reply #55 on: 07 January 2019, 10:41:38 PM »
I am also a RUB man.
I have about 80 of the 4L/9L variety as well as a few larger ones 18L/21L.
I think I need to buy a few more.
rct75001
« Reply #56 on: 07 January 2019, 11:49:00 PM »
Steve, Litko in the US will do custom cut adhesive magnets
Richard
And she said “You haven’t bought more of those little men have you?”
https://rctlittlesoldiers.blogspot.com.au
« Reply #57 on: 08 January 2019, 07:58:31 AM »
I put magnetic sheet on the bases of all my figures. Then use metal storage containers, or thin steel paper in box files or RUBs.
As for cutting the magnetic sheet - this is very easy to do with a knife and a ruler. I also cut mine a couple of mm smaller than the base they are going on, makes cutting easier, and picking up figures a little easier.
« Reply #58 on: 08 January 2019, 04:00:54 PM »
Richard
Thanks, I've bought from Litko before.
Thoroughly recommend their products and service.
Unfortunately the import duties are eye watering.
So UK based would suit me best.
Nick the Lemming
Captain
« Reply #59 on: 08 January 2019, 04:20:44 PM »
I got some good recommendations here: http://www.pendrakenforum.co.uk/index.php/topic,18085.0.html
Pages: 1 2 3 [4] 5 Go Up Print
