20 September 2021, 09:27:08 PM
330374 Posts in 18861 Topics by 2328 Members
Latest Member: fwav8or
| |-+  Genre/Period Discussion (Moderator: Lord Speedy of Leighton)
| | |-+  Tell Techno.
Pages: 1 ... 20 21 [22] 23 24 Go Down Print
Author Topic: Tell Techno.  (Read 82191 times)
Thread Derailment Specialist
« Reply #315 on: 13 March 2021, 07:15:38 PM »
Yeah, I've had that dream ...
 Grin Grin Grin
Techno II
« Reply #316 on: 14 March 2021, 07:47:57 AM »
Stop it  !  Grin Grin Grin
Cheers - Phil. Smiley
I really shouldn't press buttons...before I know what will happen.
Probably STILL the most picked on member of the forum since the year dot.
« Reply #317 on: 14 March 2021, 08:38:44 AM »
NO !!!!!!
Techno II
« Reply #318 on: 14 March 2021, 10:53:33 AM »
Oh......Go on. Wink
« Reply #319 on: 14 March 2021, 11:02:53 AM »
Looks like the gunner sometimes sits on the trail and braces his feet on the wheels. Don't know if that's helpful Phil.
Huh, bet they don't do it like that when someone is firing back at them.
Techno II
« Reply #320 on: 03 August 2021, 09:29:57 AM »
Ermmmm.... Undecided
What on Earth does it mean when a 'cannon' barrel has a length of 31.4 cal.
How long does that equate to in either feet & inches, or centimeters ?
Asking for a friend. Liar Liar
Major General
Sir Oik of Westmarch
« Reply #321 on: 03 August 2021, 09:59:44 AM »
cal = calibre.
So, if the calibre is 3 inches, then the barrel length in your example is 94.2 inches. If it's 105mm, it's 31.4 x 105mm.   Nerd
p.s. The length of the barrel is usually measured from muzzle to breech. I'm not sure what the measurement parameters are for muzzle loading cannon (i.e., is it the length of the external tube or simply measured from the muzzle to the internal end of the tube?).
« Last Edit: 03 August 2021, 10:35:14 AM by Westmarcher » Logged
« Reply #322 on: 03 August 2021, 11:36:22 AM »
I'd presume its measured on the internal length. I suspect there was no internetional standard though. You do often see guns described described as 75mm L30 or 40 (Lee and Sherman), 75mm L43/48 (Pnz IV F-J), etc. More lenght = more velocity but above L60 the barrel tends to whip, which degrades accuracy. So the Geman 75mmL70 and 88mmL71 are less accurate than they should be. Modern guns tend to be around L60 for high velocity weapons, howitesrs and other artillery peices are much less.
« Reply #323 on: 03 August 2021, 12:16:47 PM »
We have now sent Techno to sleep
« Reply #324 on: 03 August 2021, 12:25:13 PM »
I do wonder if Phil is sometimes left feeling he knew more before our answers! Smiley
« Reply #325 on: 03 August 2021, 12:58:51 PM »
Well he DID ask.... Wink
« Reply #326 on: 03 August 2021, 01:10:25 PM »
Child: Mummy where do I come from?
Mother: < long detailed explantion of human biology and reproduction>
Child: No Mummy, Hassan in my class comes from Syria. Where do I come from?
Techno II
« Reply #327 on: 04 August 2021, 07:40:04 AM »
cal = calibre.
Thanks Davy.....Though it did take a while to stop the headache. I don't want to see.
In the 'thing' I'm remaking.....The shell would have been 3 inches.....so I'd assumed that that would have been classed as the calibre.....That's what threw me.
(A Browning 50 cal machine gun is called 50 cal, because the bullet is 0.50 inches...isn't it ?..so how does that work, if the barrel is 45 inches in length ?....doesn't that make it a 22.5 calibre ?
No...don't tell me, I'll get another headache....I was virtually mainlining painkillers, yesterday. I don't want to see)
I managed to find an old, perfectly side on, photo of the shooty thing, with a number of troops standing directly behind it....I thought I was going to have to guess their height, and work it from there.
Cheers - Phil Wink
OldenBUA
« Reply #328 on: 04 August 2021, 08:00:50 AM »
Calibre is the size of a gun barrel, so the cross section, as explained before. So .50 cal is indeed a half inch bullet size. For barrel length, if calibre is used it means simple multiplication, so cal should be read as calibres. A 40mm gun of 60 calibres (often written as L60), would be 40 x 60 = 2400mm = 2.4 m in length.
So same abbreviation (cal), but can mean two different things.
Note, a .50 cal HMG with 45" barrel length would ofcourse be L90.
Aander lu bin k lu.
« Reply #329 on: 04 August 2021, 08:01:52 AM »
Gota give you a headachce - no it would be 0.5"L22.5
Pages: 1 ... 20 21 [22] 23 24 Go Up Print
