21 September 2019, 04:31:16 AM
We've released an excellent V1 Launch ramp!
284033 Posts in 16932 Topics by 2189 Members
Latest Member: MartinKnight1333
| |-+  Painting & Modelling
| | | |-+  ECW project - For King and Parliament
Pages: 1 ... 53 54 [55] 56 57 ... 70 Go Down Print
Author Topic: ECW project - For King and Parliament  (Read 46112 times)
Count
« Reply #810 on: 15 May 2019, 06:34:37 PM »
Those are top notch !!  Thumbs up
A Phil-a-beg is when you really, really, really want Techno to sculpt something.
OIK !!
Cheers - Phil  Wink
ianrs54
« Reply #811 on: 16 May 2019, 07:41:52 AM »
Phil, you should know by now - Nobby cant help it !!!
Muppet of the year 2019
Count
« Reply #812 on: 16 May 2019, 10:12:22 AM »
 Grin Grin Grin Grin
Very true, Ian.
Cheers - Phil  Smiley
« Reply #813 on: 18 May 2019, 04:44:33 AM »
Solved the issue of where to find about 200 30mm long pikes for my Scots Covenanter pikemen today (I got most of my pike figures from a different manufacturer and they are cast with an open handed pose). Mrs Shy wished to show me something she wanted in Spotlight, a chain of fabric/craft shops in NZ.
Spotted a pack of 200 30mm x 0.5mm pins for 7 bucks so threw them on the counter with the stuff Mrs Shy had selected.....she even paid for them  Wink
Will have to remind people to pick up the pike units by their bases.....
And yes the heads are even the correct shape - according to Reid the Scots used narrow square headed pike tips rather than the older broadleaf blade style.
Now i just need to paint 200 pikes and super glue them to the figures once they are painted....that should be fun frustrating  At wits' end
« Last Edit: 18 May 2019, 04:52:45 AM by pierre the shy » Logged
"this plan makes the Charge of the Light Brigade seem like a sensible military operation"
« Reply #814 on: 18 May 2019, 05:37:14 AM »
That's a good solution Smiley
If you want to super glue them to the figures when you clean them up I'll paint the pikes when I paint the rest of the figures
That should avoid damaging the paint work on the pikes or the figures Smiley
After a busy work week I finally made some more progress on the Irish
Scabbards and belts done Smiley
Count
« Reply #815 on: 18 May 2019, 08:26:37 AM »
Enjoy !! Wink
As an aside to that....But still 'on topic'.
I've always found sculpting open handed figures a right pain in the bum...especially at the 10mm 'scale'.
If the pike is going to be made as an integral part of the model....I can fix the pike into the base and then 'attach' the arm, plus hand, to that....very straightforward, as the arm's 'armature/former' can be made from a very thin sausage of green stuff, which, once set, can be sculpted over....Usually with a very 'soft' putty, made up of a 50/50 mix of green stuff and Magic Sculp.
This saves all the hassle of using a piece of ultra fine brass thread as the arm's floating 'former'....Then sculpting over that......THAT is really, really fiddly.
Recently, Dave wanted a couple of open handed pikemen for his Elizabethan project. I don't want to see
I experimented, by using a thin piece plastic rod as a replacement for the brass,  which I would have been using, if the pike was intended to be an integral part of the model.
This was very much like making a (for me) 'normal' "Man holding pike."
To my delight....Once the arm had set..I was able to carefully pull out the plastic rod, leaving the pike man with a ready made open hand. The green stuff hadn't stuck firmly to the plastic rod....Just as I hoped !
No swearing, at all !!
I hope that makes sense....and just maybe some of you just might find that a useful tip.
mad lemmey
Count
« Reply #816 on: 18 May 2019, 10:36:38 AM »
Fab
« Reply #817 on: 18 May 2019, 10:47:05 AM »
He hasn't mentioned that as he withdrew the plastic rod, he jabbed the other end into his nostril.
ianrs54
« Reply #818 on: 18 May 2019, 11:48:50 AM »
What AGAIN !!!!!  Wink
Count
« Reply #819 on: 18 May 2019, 03:28:16 PM »
It wasn't my nostril.....It would have been my eye, if the Optivisor hadn't got in the way.
(That was a complete lie.....I didn't even have to 'force' the plastic rod out.....You wait...next time I try this I'll be over confident, and it'll all go tots up. Wink)
ianrs54
« Reply #820 on: 18 May 2019, 04:26:43 PM »
Tots up  - some strange Welsh expression I assume ?
Count
« Reply #821 on: 18 May 2019, 04:42:05 PM »
 Wink
I refuse to answer that question, on the grounds that I might incriminate myself.
ianrs54
« Reply #822 on: 19 May 2019, 09:17:01 AM »
It's not MIGHT, it's WILL !
« Reply #823 on: 19 May 2019, 09:34:44 AM »
Metal work done on the Irish Smiley
More figures picked up, Dragoons & Forlorn Hope. Pierre the Shy is sorting and cleaning them up faster than I am painting them Hurry up!
« Reply #824 on: 19 May 2019, 08:43:47 PM »
Pikemenís stockings done Smiley
Pages: 1 ... 53 54 [55] 56 57 ... 70 Go Up Print
