Pack composition
Started by Phil_Gray, 20 November 2010, 08:34:48 PM
Phil_Gray
Is there a guide to the pack composition of the Austro-Prussian war packs?
Yes, I don't get out much....
Megamatman
Hi Phil,
I don't know off the top of my head - but I'll find out and get back to you!  :)
What are you after? - poses per pack?
Thanks,
Matt
Megamatman
Hi Phil, there's quite a variety, but the packs generally have 2 poses, and command figures.  If you need more specific info, let me know which packs in particular you're interested in.
Phil_Gray
That's the sort of thing - is it a mix of regulars of that troop type, plus relevant command, and how many of each.... :-)
Phil
Quote from: Phil_Gray on 23 November 2010, 08:47:19 PM
Phil
Most foot are two poses, with a command set of general, standard, musician.  So 27+1+1+1 = 30 figs.  Like I said though, there's some variety.
Mounted are usually one pose, a few with two, and again the same command set.  So 12+1+1+1 = 15 figs.
Phil_Gray
bang on the button!
Sounds like their designed to fit with battalion/ regimental command?
Does that mean the AU16/ AU17 packs fit with the higher commands?
Quote from: Phil_Gray on 25 November 2010, 09:27:54 AM
Yep!
