Seven Years War Casualty Figures
Started by T13A, 04 June 2018, 08:01:37 PM
T13A
As there are no casualty figures in the Seven Years War range (hint for Leon  ;)), I was wondering if the casualty figures in the American War of Independence range would do instead? Grateful for any help.
Cheers Paul
T13A Out!
We've been asked about them a few times over the years but they've never made it onto the sculptors lists.  The AWI ones will work fine for the timebeing though.
T13A
Hi Leon
I thought so, many thanks.
Paul
T13A Out!
I have used the AWI casualties for the SYW. However if I were you I would put in a request to Leon to remove the figures in hunting shirt and replace them with a mix of the other figures. One of the nice things about this casualty pack is the separate headgear that can be positioned next to the casualty.
I use those for SYW; quite acceptable.
cameronian
I use them for 1866, fine with a bit of filing and paint, also you can artfully position clumps of grass etc to obscure anything you want left unseen.
One of them has turned up on a French 1870 artillery base and looks the business.
WeeWars
www.supremelittleness.co.uk
