25 October 2020, 02:02:04 PM
308782 Posts in 17958 Topics by 2266 Members
Latest Member: michaelk
| |-+  Requests
| | | |-+  SYW Suggestions
Author Topic: SYW Suggestions  (Read 2896 times)
YORSTONS
« on: 16 November 2010, 08:55:01 AM »
Hi Leon,
Any chance of some (i just no this will be wrong) Arquibsiers De Grassin for the SYW, everyone else seems to have some sort of light infantry except the French.
Also some general purpose 19th century wagons and perhaps a ambulance.
Zbigniew
« Reply #1 on: 17 November 2010, 10:56:26 AM »
Hi Leon,
For Arquibsiers De Grassin you can try Russian pandours with French command. I have made Fischer's Chasseurs this way (I can post a photo this evening if you wish)
« Last Edit: 17 November 2010, 10:58:40 AM by Zbigniew » Logged
lentulus
« Reply #2 on: 17 November 2010, 12:48:01 PM »
I'd like to see that, please.
Zbigniew
« Reply #3 on: 17 November 2010, 07:10:33 PM »
Here they are
Wkeyser
« Reply #4 on: 14 December 2010, 11:10:29 AM »
Hi I know there are grenzers but they are "skirmishing" how about some with port arms or just firing, but with out the cape. They where more often than not used as line troops during battles, the petit Guerre saw them "skrimishing".
William
kustenjaeger
« Reply #5 on: 14 December 2010, 01:25:13 PM »
Greetings
I think that the SYW Russian pandours do not have the cloak - a post under SYW pandours and grenzers noted:  "The poses of Pandours are almost the same [as the Grenzers] with the exeptions [sic]:
1. dudes dont have cloaks
2. commander figure has sabre and pistol instead of musket"
In the SYW grenz battalions were not, as far as I am aware, used as formed troops - they were trained to be able to fight in formal order after the SYW.  Where they took part in larger actions in the SYW they generally held broken ground (e.g. Lobosch Hill).
Regards
Edward
Wkeyser
« Reply #6 on: 15 December 2010, 09:03:12 AM »
If you look at the battle of Moys in 57 they are formed and attack up the hill against Prussian Grenadiers. I think Duffy also talks about their use as formed troops but will check that again. I am not sure what is actually meant by Skrimish as we gamers usually equate that with Napoleonic, which is even then often off the mark. I will do some reasearch into this but am pretty sure that they where used as formed troops but had the ability to hold "rough" ground, but it seems to me that I recall even this was done formed, but I might be wrong and will go back to Duffys Instrument of War the bible for Austrians of the SYW.
Thanks for the tip on the Russians.
William
