Identifying units in the same division in Black Powder
Started by Orcs, 11 October 2017, 05:00:30 AM
Yes, if you're referring back to an army list it's no great mental hassle. At least until the third lubricating beverage goes down and brigades end up hopelessly intermingled, but there's probably no hope by then whatever you've chosen ;)
I think there are two distinct situations here, giving rise to whether or not to permanently mark. Most of the games I play with my 10mm figures in the FPW have fixed unit sizes. Permanently marking the base is not a problem. In the SYW I also use units of a fixed size, identified by flags and cuffs/lapels etc. However in 6mm FPW, when I am doing BBB and unit size can vary from battle to battle I attach a small label to the command stand along the lines of 5/T, i.e. the unit started with 5 bases and is trained so will be spent when it drops to three bases.
I like that approach, Leman - anything that makes it obvious from a glance is good. I don't mind the record sheet > hidden mark approach but it's nice to see at a glance.
The brigades the units are in will vary from game to game, so I need something that is a temporary marker
11 October 2017, 09:58:31 PM #19 Last Edit: 11 October 2017, 10:33:59 PM by GrumpyOldMan
Hello
For temporary markers I use envelope labels. You can write the details on one end, fokd ovet to make a tab and use the sticky part onto the underneath of the base. This leaves a tab sticking out from the rear of the base with the required info. I hope I've described it ok. If not I'll take a photo.
I regularly print markers for my units. If all you want is to differentiate Brigades, I would recommend a simple piece of coloured card, glued with PvA  to the underside of the base, with enough protruding for you to distinguish between Brigades.
Mollinary
Quote from: GrumpyOldMan on 11 October 2017, 09:58:31 PM
Hello
No that's perfectly clear thanks
Quote from: mollinary on 11 October 2017, 10:22:43 PM
Mollinary
Sorry that won't work as they are not in the same brigade  every game
Quote from: Orcs on 11 October 2017, 10:50:43 PM
Well, I would respectfully disagree. The bits of card cost peanuts, and you can replace them after any battle. Simplicity trumps minimal costs anytime for me.
Best,
Mollinary
Use blue tack instead of PVA and you can juggle the labels / coloured cards around
I presume the dab of PVA is small enough you can just pull the tab off? Then you can add another in a different colour/marking for the next game etc.
I'd be tempted to pop a little sticker somewhere visible but unobtrusive on the base.
Orcs asked for advice, loads has now been given. Take your pick.
And his favourite tune is Ace of Spades. I saw that one coming, he said, hammering the point home. Or as the chainsaw said, don't get me started.
Coat!
Quote from: toxicpixie on 12 October 2017, 09:03:43 AM
Absolutely!
Mollinary
