18 May 2013, 06:28:25 PM
We are now stocking some of the excellent resin items from Anarchy Models
75748 Posts in 6088 Topics by 1172 Members
Latest Member: AlberthaS
|-+  Wargaming Topics
| |-+  Rules
| | |-+  Black Powder WSS with Pendraken
Author Topic: Black Powder WSS with Pendraken  (Read 613 times)
Gunfreak
« on: 30 October 2010, 02:52:06 PM »
I'm doing two WSS project, one will use the new 28mm plastics, and then one with pendraken.
The 28mm project will be small 3 small infantry brigades and 2 semi big cavalry brigades, but in 10mm I can get it alot bigger.
The plan is 30 strong battalions, on a single base, I do this because there realy wasn't that much change in formation for the peiod, this apears to be the most liniar of all liniar warfare periods. the base will be 50x30mm big with 30 figures in 3 deep formation.
So the question is how big can i go. with a single battalion only taking up 50mm of frontage I can get quite a big battle,
Lets say 5 battalions in each brigade and 5 brigades of infanrty
Then another brigades of cavalry with 3 regiments pr. brigade
Thats quite alot. But would look realy good.
« Reply #1 on: 18 November 2010, 02:39:18 AM »
The problem you are going to have is playing measurements.
In the rules, where the measure unit (MU) is 1 inch, a Bn has a frontage of 24-27cm.
if MU-cm that gives a frontage of 10-12cm (40%)
5cm frontage means having to halve the measurements in the book, so close range =3cm, and infantry moves 6cm.
I know you have limited room, but that means the playing area is only 36cm x 72cm (equivalent to a 6' x 12' 'full size' table)!
Will Wargame for payment
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
