French Legionaire at Indochine
Started by Natxo, 28 June 2017, 06:25:54 PM
Natxo
Hello:
Can someone tell me which reference could be used to represent this guy?
https://goo.gl/photos/xhNjkSmKx5hHABXd9
It´s a french legionaire at Indochine, during World War II. French colonial uthorities fought a war with Thailand, then under a far right government.
Would this do?
SC2 Dismounted Camel Corps
Hello Natxo
Most of the pictures I've seen show shorts and a Wolseley type sun helmet. I use the WW1 British Middle East range. I'm out at the moment but I'll see if I can find some more pics.
29 June 2017, 12:38:30 AM #3 Last Edit: 29 June 2017, 12:49:21 AM by GrumpyOldMan
Hello Natxo
Here are some more images:-
And one from the retreat to China:-
When the new WW1 British Middle East figures are released it will make it easier - http://www.pendrakenforum.co.uk/index.php/topic,15005.0.html
You'd have to do some work on the HMG, either swapping an Hotchkiss onto the Vickers base or a head swap onto a SCW Hotchkiss base, probably generic Winter regular army or Moroccan Falange.
I probably have some links from when I looked at this. You can find most of the equipment apart from the amphibious tank.
Here is a pic, from a blog I can't remember whose,  of the WW1 figures that could leap into action as French colonials apart from the Vickers :).
Natxo
Thank you for your answers.
I think that the new WWI miniatures will be perfect, and I can mix them with those dismounted Camel Corps.
The HMG should come form the SCW, it´s easy to swap heads or make a new hat.
Thai infantry will be easier, the adrian helmets ask for french or italian miniatures, and the peaked caps for wwI british.
I don´t know wHich MG did they use, but I will keep looking up in internet.
02 July 2017, 08:43:31 PM #5 Last Edit: 02 July 2017, 08:59:41 PM by GrumpyOldMan
Hello Natxo
Just be aware that the dismounted cav sun helmet is a different style. It is taller with a narrow brim. Yes head swaps are easier.
I used WW1 Italians for Thai but that was before the WW2 French chasseurs in vareuse were released. Adrien helmet, short jacket and putters would be a better proxy. The Thai were using Madsen lmg and Browning hmg. The fm24/29 lmg is close enough at arms length and I used WW1 British Vickers with head change.
But I'd use FRE25 as the officer
Hello
I also had fun with an armoured train  :D.
Train Indo 1
Train Indo 2
