Atlas Editions Vulcan 1/144 £1.99 !
Started by Sunray, 30 January 2017, 03:04:17 AM
Sunray
I saw this offer on TV from Atlas Editions. It is 1/144 which would provide a backdrop  for games or diorama.    No much use on the table, although Cold War they were trained in  low level in a conventional strike role.
Anyone see any catch with this offer?
O Dinas Powys
O Dinas Powys
Quote from: O Dinas Powys on 30 January 2017, 09:50:05 AM
Just trying to find the catch in the Terms and Conditions...  :-\
OUR OFFER, YOUR GUARANTEES
    > No need to send any money now.
    > You will receive the latest model from the Jet Age Military Aircraft Collection approximately every 4 weeks, unless you inform us and you will only be charged once you have received your exclusive Jet Age Military Aircraft replica.
    > You are 100% free to cancel your collection at any time. Just write, email, call and say so - no explanation is necessary.
    > One application per household.
Sunray
For £1.99 that's a lot of 1/144 aircraft.  A good theme scenic for a character game.  RAF Vulcan goes missing with nuclear bomb load.  Located on remote Third World airstrip.
Special forces in overt mode (Falklands Paras with sand coloured berets) are dropped in to secure.  Local war lord hears about it and send jeeps, lorries, BTR 152 and T.34.
GAME ON !
Oh just need those North Koreans to act as Proxy militia -   =P~  Where are they Phil ?
Sunray
The Vulcan arrived this morning - impressive model for £1.99.
As O Dynas has explained - receive, pay and cancel any further shipments - otherwise they send you a model you don't want EVERY month1  X_X
The Model is ideal for a modern scenario - not as a weapon (what's the 1/150 scale of 60,000 ft? Although it might have an application at low level ?)
Mine will be parked on the ramp as a scenic in a bush war game to recover a nuclear warhead..
SV52
It will of course cost considerably more for subsequent editions, same as all these things over past years.
Quote from: Sunray on 30 January 2017, 03:55:47 PM
Sitting on my desk, to keep from putting even more moulding pressure on Leon & Dave.  :D
Cheers - Phil  :D
Quote from: Sunray on 10 February 2017, 12:10:56 PM
Vulcan - the ultimate close air support aircraft?
Can you sort of imagine the look on your opponents face when you make your close air support role and in comes the Vulcan at low level to lay a line of thousand pounders across the table....
Flying in lower than 50', they had to pull up to bomb height, or they wouldn't get the bombs to arm!
Didn't at least one low flying Vulcan hit a cactus at a test range in Nevada  :o
Surely this is a "must have" if you game the Falklands ?
Already got a Tumbling Dice one for that!!! ;)
Quote from: Orcs on 10 February 2017, 08:35:10 PM
Your Marines/Paras/Guardsmen/Ghurkas might have to wait quite a few turns for the Vulcan to show up......quite a distance from Ascension Is to the Falklands  ;)
Sunray
Quote from: pierre the shy on 11 February 2017, 02:29:04 AM
At high altitude they could operate in the thin air and drop on a big target like the airfield.  The Vulcan  is not battlefield interdiction precision bombing kit.
If I had told that a Vulcan was coming to provide close ground support to troops in a firefight, I would have dug a very very deep hole, got in it, bent over and kissed my arse goodbye. :-h
However, I love your line about the look on an opponent's face.  :x  as one is placed on its stand on the table !!
Now if the Pussers had had an old fashioned traditional carrier and a flying banana or two. The Buccaneer was the queen of the Killing Ground on low level strike - the Task Force would have had ground moving  air support.
