Super Glue - any difference in cheap or branded?
Started by Orcs, 28 January 2017, 11:21:28 AM
Quote from: Orcs on 28 January 2017, 03:10:07 PM
No he does actually mean "Wee" bottles.  After Eons of inhaling green stuff and Cyanoacrylates fumes he now literally "wees" superglue. This can be a little difficult as if he does not "shake" properly he gets stuck to the inside of his Y fronts.  It does however save him a fortune when gluing figure together.
I am sure if you asked him nicely FSN he would send you a sample to try! :)
There was an old harlot from Kew
Who filled up her inside with glue.
As she said, with a grin,
"If they pay to get in,
They'll pay to get out of me too."
NTM
Loctite for model assembly cheap stuff to glue figures to paint sticks.
Quote from: Orcs on 28 January 2017, 03:05:55 PM
How do you stop the thin little nozzle from blocking up?
By dabbing it with a bit of kitchen towel......OR pushing a 0.5 mm pice of brass rod down it.....Or simply chopping off the very end of the nozzle.
jambo1
I have to use the stuff that does not produce any fumes so cheapo stuff is out for me. :(
cameronian
There was an old couple from Delhi
Spent a lifetime belly to belly
because one night they used Araldite
instead of petroleum jelly
A Welshman who looks underfed
has a face that will turn rather red
when he reads those ditties
that mentions your bitties,
I think thats enough to be said.
Things where the delete button will start getting used, if it gets any worse.  :P
I do think some of these are very close to delete.
Why is the only one I can remember 'There once was a young lady from Ealing....'
To attempt to re-rail the thread (and thinking of Pendraken tanks and animals), I offer:
There once was a fellow named Lew
Who incessantly used superglue
To his forehead was stuck
Three goats and a duck
And to his thumb a T thirty-two
When buying a new superglue
There are several things that I do
Check value and price
and, done in a trice,
Block nozzle with needle or screw
A gamer who wanted some Aztecs
Had rather a serious problem:
When he tried for a rhyme
In a limerick's verse,
Even the scansion went wrong in the last line.
Loctite 454.  Prices vary enormously.  20gr tubes on ebay are good value.  Always used to the last drop.
