Reduce the mountain!! 2017 painting progress!
Started by petercooman, 05 January 2017, 02:32:47 PM
Spent ages painting this one!
3rd line lancers from Jacquinot's division.
Somehow the middle pennants look like black and white, but all are white and red.  think the shadow was playing with the camera!
12 models added
252 models finished!
And more importantly, all cavalry i have lying about (in 28mm) have been finished!
Oh Peter! just when I pack my 28's away so that I can crack on with other stuff .......... you make me get them back out again!
Very nice, I am assuming the cav are on 60mm frontages?
They are 60 x 45. Based for napolonic wargaming by neil thomas.
They lack the command models, but seeing they cost me 12£ in a warlord games sprue sale I'm not too picky  ;)
I wonder if they would suit black powder too. Infantry are based on 45 x 40.
All units are made up of 4 bases.
The only requirement that Black Powder has is that Small, Standard and Large sized units can be represented. If you take your 4 bases (200mm) as standard, then going to 3 bases for small and 5 or even 6 bases for large would work fine. For myself, I think you could get away with 3 x 50mm bases for standard (6") with inches converted to either half inch or a centimetre.
Is there any problem with only using standard size units? I'm guessing no, but wanted to check anyway.
I've been looking at the waterloo starter for black powder lately (and the la haye sainte set) so am interested how my forces would fit in.
Although the more I look at the buildings in that set, the less interest I have. The 4 ground farm just looks way better.( the warlord games buildings has no interior)
I use the same sized bases, with more or less figures on it!
Problem is, I already have 6 cavalry regiments and 16 infantry regiments. All 3 cav/6 infantry to a bsse (except the lifeguard  they have 2 cav per base). All are 4 bases strong
Toying with the idea of mounting two skirmishers on a 20x40 base to add to the side to denote larger units. Or just mark them as a large or small unit.
Just sticking with standard sized units is fine - if you were doing a historical scenario and simply had to reflect a large unit, then as you suggest that can easily be accommodated.
No, the unit takes x hits, shakes, then breaks. So units are only removed when no longer combat effective (or completely knackered)!
Ok.
Might be able to extend the unit frontage for big units using a mounted officer then, justput him on a 30x40 base and pop him inbetween the command stand an the troops.  :D :D :D
I wouldn't worry too much about the smaller and larger units. We hardly ever used them in HC. Small is easy, just use 2 stands. For large either just use a couple of stands from another unit, or use your base extending tactics!!
