Rommel by Sam Mustafa
Started by Fenton, 27 November 2016, 12:36:40 AM
Many moons ago when we first started playing V&B we used roster sheets, then we changed to data strips and markers doing away with the roster sheets. We found it really speeded up play and significantly reduced confusion over the status of units YMMV
doctorphalanx
I much prefer on-table indicators and I don't mind info strips at the back of bases. However, I wouldn't want to have to replace the info strips after each game because the damage track had been marked off. There should be a satisfactory way round that but I haven't yet worked out what it is...
Quote from: doctorphalanx on 03 August 2017, 09:33:26 PM
Cover it in adhesive clear plastic (I just bought 10metres by 45cms for £5 from WH Smith) and then mark off the damage using a water soluble non-permanent marker. You can then wipe it off after the engagement.  If you print info strips off onto a sheet of card or paper, I find it easier to stick the adhesive sheet to the card before cutting it up. Hope this helps,
Mollinary
doctorphalanx
Excellent. Thank you.
Quote from: mollinary on 03 August 2017, 09:49:36 PM
Mollinary
doctorphalanx
There are a couple of posts on my blog with pictures of proposed bases for 3mm miniatures.
This is the original post which envisaged using 60mm-wide bases:
https://doctorphalanx.blogspot.co.uk/2017/08/3mm-minis-for-rommel.html
This is a look at 40mm basing:
https://doctorphalanx.blogspot.co.uk/2017/08/3mm-minis-for-rommel-part-2.html
Looking cracking!
Tempting...
Nick the Lemming
For the Rommel playtest, I often used my 3mm stuff, which are on small FoW bases, with a strip at the back for unit details. They worked pretty well that way.
What websites if any would people recommend to find TOEs etc that would be suitable for Rommel?
doctorphalanx
As each base represents a company you don't really need to know what the organisation was below company level provided you know what that company's basic equipment was, e.g. did it have Panthers or a Panzer IVs. That sort of information isn't too hard to come by and I expect the army list creator in Rommel and subsequent scenarios will in any event be a good starting point though you may have to research which particular tank variants were around at the time.
If designing realistic forces, historical OOBs are probably more instructive than theoretical TOEs. I'm always interested in OOBs and don't mind paying for books within reason, but I've never really hit gold in that area. I have previously bought some Nafziger data sheets for more obscure conflicts (such as the Chaco War) and I believe it may be a (possibly the) major source for WW2. The website is at http://www.nafzigercollection.com/shop/
I've recently been researching the Battle of France 1940 and have found some useful information online. I will dig out the links if anyone is interested in that particular campaign, but I haven't found a general source of information covering the whole war.
Nick the Lemming
I'd go with Nafziger and the Micromark lists on wargamesvault.
doctorphalanx
On the subject of OOBs, I generally like to base my wargame armies on forces which participated in a given historical battle or campaign. (My SYW armies, for example, are based on forces present at Rossbach and Leuthen.)
The army creator in Rommel will undoubtedly allow you to create a representative force while the historical scenarios will prescribe more rigidly what you should have for a particular battle.
As a basis for either approach my ideal starting point would be to model complete historical divisions. Who could resist the appeal of carrying a whole division  in a shoe box?
Shecky
I came across this site many years ago when I thought about writing my own grid based WWII corps level miniature game:
http://www.niehorster.org/000_admin/000oob.htm
Luckily Sam wrote just what I was looking for :)
doctorphalanx
This is a good source for the French Army of 1940: http://www.littlewars.se/french1940/oob.html
For the Germans I have the Osprey 'Panzer Divisions: The Blitzkrieg Years 1939-40'.
Bob Mackenzie's webpages at http://www.testofbattle.com/upload/bob/ are very useful indicators even if you're not using the same rules.
Wikipedia is also a good place to start for specific battles.
doctorphalanx
On reflection the data sheets I referred to must have been MicroMark. Nafziger may be the final word but buying all the books necessary would be very expensive.
The Axis History Forum https://forum.axishistory.com/ also has some links to source material.
