Rommel by Sam Mustafa
Started by Fenton, 27 November 2016, 12:36:40 AM
I'm interested in this game. It does seem to have some board game elements.
But the idea you can do all of D-day on a few tables is intriguing.
As I can field a British armoured division at 1 stand = a platoon, I wonder what I can field at 1 to company scale.
Quote from: fred. on 12 January 2017, 06:09:41 PM
Everything?
Had a rummage through the figures, and I was clearly mis-remembering what I have, and had forgotten that I had rebased a lot of stuff for CoC as 1s and 2s.
While I have enough tanks for all 3 regiments of an armoured division at 1:platoon scale, I don't have that much infantry.
I pretty much have all the troops for a late war British infantry division, with 3 brigades, of 3 battalions each of 4 companies. Along with AT, AA, Engineer, and MG regiments. Field artillery seems to be represented at 1 stand per regiment, so just need 3x 25pdrs for that.
What I do have left in large numbers are carriers, 3" mortars and 6pdr AT guns - these seem a bit un-needed at company scale.
On the left is an armoured division, I can easily field the 3 armoured regiments, each of 3 Shermans and 1 Stuart, along with the Motor Battalion. The Infantry Brigade is a problem, would need another 12 infantry stands for this. Then the divisional troops are fine, with Armoured Recce Regt, Armoured Car Regiment, AA, & AT. And 1 SP and 1 towed artillery regiments. Could swap the Shermans for Cromwells to do 7th Armoured Div.
On the right an independent tank brigade. Dead easy with lots of Shermans. Could probably field another of these. But haven't got enough Churchills for a full Brigade.
And at the middle right is an AGRA, with 1x 25pdr, 4x 4.5" guns and a 155mm gun.
Not pictured I have plenty of 79th AD stuff for most likely scenarios.
Also dug out my British and American Airborne
Again both have had in-roads due to CoC, but it looks like I can field a division of each. It also seems that the Arnhem area, from drop zones to the bridge, will just nicely fit on a 6'x4' table at the default scale of 6" to 1km.
British Airborne division - gone for 2 parachute brigades with 3 companies per battalion, and a larger air-landing brigade. AT and Artillery, along with Recce at the top
Now that's gonna be a scrap!
Nice collection Fred
After reading more of what Sam Mustafa has said on the Honour site about squares and distances I am drawn to the idea of the game even more
Very nice collection you have
In true wargamer fashion I listened to Sam's podcast and immediately wondered if it could be converted to WW1
Try PETER Pigs "Squarebashing" :)
Looks cracking in 10mm!
Quote from: Womble67 on 15 January 2017, 12:49:18 AM
Thanks chaps - does need a bit more basing and finishing off, as these photos show.
Quote from: Fenton on 15 January 2017, 10:20:42 AM
Me too.
But I am thinking of Market Garden at the minute - got the books out, looking at maps. Lots of bits of key action happen in the right sorts of areas to be covered by these rules.
So many choices spring to mind. Though Arnhem even though I have played it multi player would be interesting
Hmm, I was hoping for something a bit larger scale than 1km = 6", that's only one up from Spearhead (and not even that with the alternate ground scale!).
Still, company stands is a good plan? Or are they larger - battalion or similar?
Yes, company stands. The scale is down to the size of squares you go with. 6" is the default, and I think based around 15mm miniatures, I think a 1x2" base size is mentioned. If you have smaller figures/bases then you can use a smaller square size and get more geography on the table. I was toying with a 5" square, but it makes little difference on a 6x4' table.
Nick the Lemming
Quote from: fred. on 15 January 2017, 01:58:11 PM
You can use whatever size squares you want; we've been using mostly 6" squares, whether with 15mm, 6mm or 3mm, but if you have a smaller table and smaller figure, you can cut that down to 3" or 4" squares if you wish. If you want to use 25mm, you could even go for 8" or bigger squares, as long as you have a bigger table.
You can certainly use smaller squares *and* a larger table if you want big epic battles, but you'd probably have to increase the forces used, and add some more game turns in, otherwise you run the risk of hardly getting into contact before the game ends. It will affect the scenario objectives too - more spread out, and the attacker is going to find it harder to take and hold specific sites; it's going to take longer to get off the other end of the table, that sort of thing, so you might have to tinker with other stuff too.
