Highly annoyingly I went to base up the Savoy foot guards and have lost my bag of pre-cut pikes. Doubly annoyingly I also received postage confirmation of my recent order so I can't even piggy back that!
A long painting hiatus has been broken by base coating another T-28 and the monster that is the T-35. The latter comes in at 65mm long, give or take, and weighs quite a bit. However it is a lovely model. Not sure whether to add camo to it to go along with my other Soviet kit, or just to leave it plain Russian Green :-.
Plain green. With a big red star on the side.  :D
That be parade finish. However I suspect cammo is a later addition, so plain green would feel right, probably with some form of tactical markings on it.
Plain green is correct and the red star was for a parade, from the info I've been able to find. There is an image with a white triangle on the turret side, so might try that. There are also some turret rings for identification, some plain white, others a red band with white stripes. These I think will be beyond my painting skills, as much as I might like to do them. Off to do a bit more research... :)
Have seen T-26's and T-28's with a white ring round the top edge of the turret, as an air id marking I think. That and white code numbers.
And in 10mm Renaissance:  48 knights and 12 handgunners nearly finished.
Sleep with clean hands ...
Goes with borderline insomnia and depression! ;)
Certainly some seem to have made it near to Germans whilst sporting a red star. I think1 of my 3 T35s sports stars.
Nicely turned out
Yep, found the same 'photos earlier today FSN, so mine will have red stars too :).
Slight diversion from tanks this evening into painting some scratch built ruins I made 3 months or so ago, as they are taking up space in the painting tray and I could use them for my planned BKCII game.
Renaissance stuff done, photos later!
I think I have sourced the problem with the T35. We have always assumed it was underpowered, unreliable, over large and under armoured. In fact, it was the perforated turret tops that let it down.
Do you mean the crew drowned when they took it out in the rain?
The Germans thought it was an instruction to "tear here", so they did ;)
